Old 07-15-2004, 10:16 AM   #1
cyba888's Avatar
Default who here use the Ko Propo electric switch?
The only downside to this is that it drains your bettery even when its turned off. Does it drain the battery very fast or can you get a few good hours using it without draining your batts?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 07-15-2004, 02:49 PM   #2
Default switch
good switch, when it is off it's on when it's on it's off. go figure
haywyre is offline   Reply With Quote
Old 07-18-2004, 04:27 AM   #3
B4
B4's Avatar
Default Re: who here use the Ko Propo electric switch?
I'm using this switch on my 710. The only thing i do is disconnect the switch from the battery after the days racing. If you don't do this and are using NiMh batteries it will take to much out of the batteries and reduce there life.
I see other people don't use any switch at all, but I don't like that. In my case i also need to carry some extra weight as the car is under weight.
B4 is offline   Reply With Quote
Old 07-18-2004, 09:11 AM   #4
serpentsixty9's Avatar
Send a message via AIM to serpentsixty9 Send a message via Yahoo to serpentsixty9
yah, i used it for a while, and everytime i was done runnin my car, i'd press the off button, and i knew i had a good 1/2 a pack left but when i went to go run it again, it was drained, i never liked it, it just drained my batts, when it was in the off, so i had to either unplug my bat from it, or just get a manual one, and i got a manual one, its a lot better and cheaper. mho
serpentsixty9 is offline   Reply With Quote
Old 07-18-2004, 09:21 AM   #5
cyba888's Avatar
Anyone else having fast battery drains from using the switch?
Futaba 4PX
Old 07-18-2004, 10:37 AM   #6
jeffreylin's Avatar
R/C Tech Charter Subscriber
Derek, I have one on my FW05R in LA. It drains your battery in a couple of days but works fine otherwise. I had no problems going through a race day with the switch--i.e. it does not drain the battery so much that you have noticable shorter run time compared to a regular on-off switch.
jeffreylin is offline   Reply With Quote
Old 07-18-2004, 10:48 AM   #7
cyba888's Avatar
I talked to you about that today at the track but I thought you didnt have one. Anyways glad to hear it works just fine. Have a safe trip back to LA and ill see you in a month or so. Hopefully you will have your new V One RRR
Futaba 4PX
KO Propo switch dgraham225 Radio and Electronics 2 02-25-2008 06:32 PM
KO Propo on/off push button switch IDrinkNitro R/C Items: For Sale/Trade 2 08-22-2004 09:05 PM
KO PROPO Switch IDrinkNitro R/C Items: For Sale/Trade 0 08-05-2004 07:05 AM
Ko Propo Electrical Push Button Switch New IDrinkNitro R/C Items: For Sale/Trade 0 07-18-2004 05:50 PM
Where to purchase Ko Propo Electric Switch online? cyba888 Nitro On-Road 11 07-13-2004 04:17 AM
