Old 02-27-2011, 10:51 PM   #121
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by eigthracer View Post
Where are you ordering your P81 RS's from ? and who has stock of them please ?
You can get it here:
http://www.smg-speedshop.de/shop/mai...?items_id=3422
Shoot me an e-mail or PN if you have any questions.
We already sold two to the UK..
stefan is offline   Reply With Quote
Old 03-01-2011, 06:53 PM   #122
got into the build sunday,so far it went okay,the only issue was the spacer plate under the center diff ,i dont know what metal it is made of but it is hard as hell, had to open the holes the screws go through just a little bit and i wiped out a file,carbide dremel bit and a drill bit but i finally got it!!!! aside from that this is a sweet kit!!! im going with the novarossi exhaust, should have that and the motonica wheels and tires next week. does anyone know which lipo receiver pack i can use? there are several sizes and i want to order the right one,thanks
beaven is offline   Reply With Quote
Old 03-03-2011, 04:45 PM   #123
just printed out the tip sheets on the p81rs build, they will definately be helpful,i canceled the nova exhaust and went with the BP set up instead. i hope to get some more build time in this weekend but this is no build to rush on and it is still too cold to run here on long island....
Old 03-03-2011, 08:46 PM   #124
garen's Avatar
Maybe Brad T can chime in on the battery question, I use nimh batteries, mainly the Motonica battery. Duratrax also makes a nimh battery in case you can't get the Moto battery, which is currently out of stock. I'll locate the part number on that battery and post it here.
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 03-04-2011, 06:14 AM   #125
YBSLOW's Avatar
Default Life RX pack
I use the life rx pack, I had too many issues with voltage regulators when I used lipos in the past. I got the one pictured from horizon hobbies. It is 1100 mah, but seems to make 1 hr mains with no problems but I always peak charge it bright before the main.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 03-04-2011, 12:57 PM   #126
stefan's Avatar
I am running 1300 mAh Lipo with High Volt servos.
There are plenty of LiPo's that will fit, 75 x 35 x 15 mm is what you're looking for.
Btw, if you are looking for a regulator that works, check the Xceed.
It's not cheap, but very reliable and small
Old 03-06-2011, 02:52 PM   #127
well she is taking shape really well, a real interesting build for sure. the tip sheets on motonicausa are a great help to the build,thanks for them!! do you need a special charger for life batteries??
Old 03-08-2011, 09:28 AM   #128
YBSLOW's Avatar
unfortunately yes, however most of the newer chargers that have a lipo function also have a life function. You need to be able to change the voltage per cell to 3.3v instead of 3.7v like the lipo.
YBSLOW Racing
Old 03-10-2011, 02:04 PM   #129
i just wanted to take a moment to thank you guys for all of your input on this build. special thanks to Garen who has responded to all of my questions in a helpful and timely fashion. great support is a hard thing to find especially when you have problems with something, i commend you for this,once again thank you...
Old 03-10-2011, 06:41 PM   #130
choisan's Avatar
any idea of an upgrade kit for the 81, i am really looking for one.
i do not want to have too many versions say in 4 years time since P8, P8R and the brand new 81(never run). I just want to upgrade it to RS.
choisan is offline   Reply With Quote
Old 03-11-2011, 12:18 AM   #131
NitroWD's Avatar
Default springs rating
anyone knows what's the rating for the stock kit front and rear springs?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 03-11-2011, 12:27 AM   #132
garen's Avatar
No news on an upgrade kit yet. The P81, P81Pro, and P81RS are essentially the same car. Everything is compatible from one to another, and in the case of the RS the only parts that really change the setup or handling are the shock towers and radio tray (with front bulkheads).
I don't know the actual rating of the springs but the stock springs are the motonica 'white' springs.
Old 03-11-2011, 01:18 AM   #133
stefan's Avatar
Any opinions on the clutch bell?
Old 03-11-2011, 06:29 AM   #134
stefan's Avatar
Ready to rock
Old 03-11-2011, 08:30 AM   #135
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
Originally Posted by stefan View Post
Ready to rock
NICE!!!!! can you keep me posted how the car perform, looking to get another car around mid summer
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
