MOTONICA P81RS
Old 11-03-2012, 07:50 AM
  #376
funs's Avatar
Originally Posted by ozace View Post
amain is the only place I could find 'some" bits.
I purchased my car from funs hobby, the only place I could find stock but no parts.
Ebay has a few items, I bought a gt shell from Italy, not a great experience but it did arrive.
Hi we now have full parts. You can check in our alibaba shop.
But you'd better order the parts in combine shipping, otherwise the parts
takes too expensive shipping.
funs is offline
Old 11-11-2012, 10:32 PM
  #377
josecarlo1129's Avatar
Am about to wrap this thing up, my new GT body.
josecarlo1129 is offline
Old 11-12-2012, 01:19 AM
  #378
Default P81 RS Rear lower and upper arms
Hi there, i need some information regarding the rear lower and upper arms for the P81RS. It seems that for the rear lower and upper arms there is 8 position that can be mount. Which is the best position that can be used for a medium high flow track with a chicane and at the same time can help the front steering to turn in better?
shambmk is offline
Old 11-12-2012, 01:17 PM
  #379
garen's Avatar
I normally run the rear lower hinge pin in the upper outer position and the rear upper hinge pin in the inner lower or inner middle position. Try this and see if you like it. Also, run the front lower hinge pin in the inner position, and the front upper hinge pin in the inner position as well, with 3mm spacers under the front upper arm mounts.
garen is offline
Old 11-13-2012, 05:15 AM
  #380
I just got a look on the updates of Xray's RX8 and surprised that it looks a lot Motonica's P81RS 2 now.
I mean no harm about this. I am just expressing my thoughts since I really like Motonica's sleek designs and will continue to.
Old 11-20-2012, 04:18 AM
  #381
Default RS3
Motonica RS3 is ready check the products at motonica.com
dsond is offline
Old 11-20-2012, 07:22 AM
  #382
Default p81 rs 2
this is a nice car wish that there was more support for the car here in the USA.
bigtee is offline
Old 11-21-2012, 04:07 AM
  #383
Suspended
thanks
adam777 is offline
Old 11-28-2012, 05:17 PM
  #384
jackcarter3's Avatar
Where you you get this body? I have been looking for one and. E mailed motonica USA to no avail.
jackcarter3 is offline
Old 11-29-2012, 01:25 AM
  #385
^got it from Amain Hobbies, sir.
Old 11-29-2012, 10:34 AM
  #386
Thanks. I have one back ordered there.
Old 11-29-2012, 10:48 PM
  #387
PNT2000's Avatar
nice.....
PNT2000 is offline
Old 12-05-2012, 02:46 AM
  #388
Default clutch shoe
Can mugen clutch shoe fit to motonica clutch system?
shambmk is offline
Old 12-15-2012, 11:55 PM
  #389
you should try the mugen wc clutch completely as it gives better punch out of the corner and better top speed compared to the motonica clutch
andy733 is offline
Old 01-21-2013, 11:28 AM
  #390
ogreasurada's Avatar
For the thrust bearings can I use the ones from other brands or have to order from Motonica? thx
ogreasurada is offline
