Old 08-06-2012, 02:08 AM   #331
josecarlo1129's Avatar
Originally Posted by choisan View Post
Thanks so much, it seems there isn't much tolerance left to the rear screw with the pulley.
Yeah, My bad, it's because I am using a cap head screw instead of a regular one. It's different when I race.
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 08-06-2012, 04:23 AM   #332
choisan's Avatar
Thanks so much.
choisan is offline   Reply With Quote
Old 08-14-2012, 05:10 AM   #333
Default rear body mount
just a simple question,do any other rear body mounts fit on the rs2?
andy733 is offline   Reply With Quote
Old 08-14-2012, 04:06 PM   #334
garen's Avatar
Andy, I have seen a a different body mount on a P81, but I can't remember what it was or how it was fitted, maybe Serpent or Mugen (not sure from what car or version of either). What problem are you trying to solve?
I have posted my baseline RS2 setup here http://www.motonica-usa.com/support.html
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 08-14-2012, 10:09 PM   #335
Default rear mount
hi garen,
i was told that the rear mounts brake easily and i was just wondering if i could try some thing a bit stronger that's all.also do you have a set up for low traction as the track i run on is both low traction and technical.
Old 08-15-2012, 12:36 AM   #336
garen's Avatar
The rear body mount is actually quite reliable. If anything, the weak point could be the two posts that protrude from it. If you roll over and hit something just right, you can rip one off. If you do, you can simply grind the broken one down, cut/grind the other as well, drill holes in their place and install any body post of your liking. I have done this before and you will see this on some of the team driver cars as well. The body mount on my car is probably the original one from when I built it a year and a half ago.
I don't have a low bite setup, but I could try to come up with one. I would recommend looking at some of the Euro setups, they normally don't race on prepped surfaces, and their definition of high or medium bit is very different from ours here in the states. Email me to remind me to send you some suggestions for a low bite track.
Old 08-15-2012, 10:03 AM   #337
Based on my racing experience, the body mount I'm still using is the the one intended and included in the P81 package. The body post is shorter (with single hole option/fixed) compared to the updated version (P81RS/RS2). I flipped on several occasions and still it's intact. I find it very sturdy and pliant and I could not afford to look for any another body mount since the Motonica got the slickest, good looking one. HTH. Cheers.
BTW, I attached a thumbnail of the body mount I am using,
Old 08-16-2012, 02:00 AM   #338
romain_f's Avatar
Hi guys,
I've been running all Motonica P81's (pro, RS, RS2), and only the first ones had that kind of problems.
Now the rear body mount is strong, it has been charged with more carbon since the pro version I think.
cheers
HB R8/Novarossi
romain_f is offline   Reply With Quote
Old 08-16-2012, 10:03 AM   #339
garen's Avatar
Carlo, the shock spring adjusting rings are upside down on your car. Also, be sure the bolt and nut you have holding the body mount to the H-arms are not too tight. The newer kits now come with a pin and collar instead of pin and e-clip, so that might be something you might want to change in the future.
One last thing, you might want to add another shim between the rear shock tower and the center pin. This will move the centering pin further out and minimize the centering plate from popping off in a hard crash. Let me know when you want to try the VMR tires, I have a fresh batch coming next month.
Old 08-16-2012, 05:16 PM   #340
Thank you very much, Garen. I really need that since I am preparing for a major race here. Hope it'll be a good one. It'll be my first race. I have quite enough spare of tires for the said event but surely, I'll be getting the VMR tires once these got depleted. You know I believe and follow your tips, religiously. Thanks and cheers, Garen.
Old 08-19-2012, 08:06 AM   #341
stefan's Avatar
Send a message via AIM to stefan
Ready for the Nationals after our vacation
stefan is offline   Reply With Quote
Old 08-21-2012, 11:12 AM   #342
PNT2000's Avatar
nice
PNT2000 is offline   Reply With Quote
Old 09-16-2012, 09:01 AM   #343
g-wan's Avatar
Send a message via MSN to g-wan Send a message via Yahoo to g-wan
Default motonica p8f
anyone drive this kit p8f? as im thinking about getting 1 of it for just seek of fun,just to get feel of this kit so i need opinion from other before proceed of buying it,sorry if i post on p81rs as i dont want too many forum post just to ask regarding p8f
km k8 / os speed / savox / blitz / contact tyre
km hk1 evo / os speed / savox / sweep
sworkz evo / spower evo s7 / sweep / savox
xray t3 2012 / tekin rs pro / reedy / savox
km racing / sworkz / xray / savox / sanwa / os speed / sweep / ulti / blitz
g-wan is offline   Reply With Quote
Old 09-16-2012, 09:25 AM   #344
garen's Avatar
The P8F line is great just for having fun on or off the track. They drive just fine.
Old 09-20-2012, 07:22 PM   #345
These things look terrific. I have been trying to find the electron version for sale but have had no luck(i am in australia). Any how i am enjoying the pics that pop up here.
I pay to play, do you ?
ozace is offline   Reply With Quote
