Old 04-26-2012, 01:31 PM   #301
garen's Avatar
23.90mm long
8.5mm diameter on the ball
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 04-26-2012, 02:15 PM   #302
asw7576's Avatar
Smile
Originally Posted by garen View Post
23.90mm long
Thank you for the information garen, ..... i appreciate it.
Old 05-28-2012, 02:25 AM   #303
garen's Avatar
P81RS2 at the Euro B championship. TQ and first overall with Arnaud Mathieu.
Old 05-31-2012, 12:22 AM   #304
josecarlo1129's Avatar
More info here, http://www.motonica.com/en/team
Cheers to the Team Motonica.
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 06-02-2012, 06:01 PM   #305
Default spare parts
just wondering where to buy spare parts for the RS,also what difference does the RS2 update do to the overall performance of the car
thanks
andrew
andy733 is offline   Reply With Quote
Old 06-02-2012, 06:39 PM   #306
amain had all the parts, don't know if they still carry them. you can ask garin if you have no luck there.
beaven is offline   Reply With Quote
Old 06-02-2012, 06:53 PM   #307
thanks for that.I will try garen if he can help if need be
Old 06-04-2012, 08:31 AM   #308
garen's Avatar
A Main does stock Motonica parts. RS2 update provides more tuning options for the P81 platform.
The RS2 front tower and lower shock mounts essentially move the shocks further out, both on the tower and on the arm. I have tried this setup and on our track I could not tell much of a difference.
The RS2 front knuckles allow for ackerman adjustment and for king pin inclination (KPI) angle adjustment. They also allow for the axles to be moved up, down, forward, rearward, or centered, just like the old knuckles did, and they also allow the axles and bearings to be removed without removing any other parts. The ackerman adjusment allows the steering tie rod end to be moved in/out, forward/rearward. You can alter the steering feel and reaction with this adjustment. The KPI adjustment can be done in 0.4mm to go from '+1.2mm' to '-1.2mm' angle adjustment. This has a similar effect as changing caster as it changes the contact patch of the tire as it rotates and it also changes the way the car rolls in the corners. With the old knuckles some drivers would run them flipped (myself included) so the new knuckles allow this to be done without any mods and to be done in any 0.4mm increment in between. There is no better or worse with this, it changes the feel of the car more than anything, but it is one more adjustment you can make to either suit the way you like the car to drive or to suit the track conditions.
Finally, the rear upper arms are replaced with camber links. This allows slightly more flex in the rear suspension, and in theory at least, should provide more rear grip.
Old 06-04-2012, 08:35 AM   #309
if anyone is interested in a p81rs mine is available. never raced,like new plenty of spares, pm me..
Old 06-04-2012, 04:14 PM   #310
thanhs for the info garen, amain have the parts but in the future if they don't have rs2 upgrade do you know if possible to purchase it thru motonica usa
Old 06-04-2012, 04:48 PM   #311
garen's Avatar
Andy, sure no problem, but A Main does have the RS2 upgrade kit on order and will have it back in stock very soon. I forgot to mention the RS2 upgrade kit also includes the adjustable blade rear sway bar.
Old 06-06-2012, 10:50 PM   #312
I must agree with you Garen. The handling of my P81 is superb since I had the RS2 upgrade.
Old 06-18-2012, 03:56 PM   #313
Default optional parts
just wondering if it's possible to use the mugen's new light weight axles in the front and rear and also if any other brands belts can be used instead of the motonica belts.
thanks
andrew
Old 06-19-2012, 03:43 AM   #314
Andy,
I've been using the Mugen Lightweight axles (F/R) on both the Nitro P81RS2 as well as the electron version. They've worked out pretty well, and are surprisingly robust
But to convert to these axles, a few other Mugen parts must also be used as well:
Mugen Front Inner drive cups
Mugen Universal Joint axles (Front and Rear)
Mugen Wheel changing lever kit (Front and Rear, including the Roller pins )
HTH,
cheers,
-m
Motonica P81RS2 / P81RS electron CRC GenX LE / Xti-WC
mjw353 is offline   Reply With Quote
Old 06-19-2012, 09:59 AM   #315
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by mjw353 View Post
Andy,
HTH,
cheers,
-m
Go with the Arrowmax parts for the MRX5. They are cheap and last forever. Don't try the titanium axles though.
Also, you don't need the wheel changing levers from Mogen, the Motonica ones work just fine.
stefan is offline   Reply With Quote
