Old 07-17-2011, 10:41 PM   #196
garen's Avatar
I have not, and I have not heard from anyone else with this problem. Can you email me a photo of the broken parts and a clear photo(s) of the front end of the car?
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 07-18-2011, 03:47 PM   #197
i found the inner hub but i havent been back there to look for the axle,the front end looks fine to me the axles didnt have excessive side to side play or anything,the suspension is all intact,i figure the only way it could have come out is to have broken. i will look at it more closely and see if my kid can take some pics when she gets home....thanks for getting back to me...
beaven is offline   Reply With Quote
Old 07-18-2011, 04:40 PM   #198
garen's Avatar
OK, so nothing broke for sure, more than likely the dogbone popped out. Are you using the washer on the outdrive and how wide is the front end?
Old 07-18-2011, 05:01 PM   #199
i am missing the washer on the left side but thats the one that fell out. it measures 8 1/8 inches from the top of the knuckles my micrometer doesnt open far enough to get it in mm,i can bring one home from work tomorrow and get a more precise measurement. i ordered the parts from amain and should have them in a few days. looking at the r/s there is a lot of side to side movement but i dont see how it came out,however stranger things have happened to me with this hobby....
Old 07-19-2011, 11:34 AM   #200
stefan's Avatar
Send a message via AIM to stefan
Out of 5 cars that are running here, we had to replace the dog bones completely on 3 cars and the front ones on another.
They's been cracked around the drive pin right out of the box. It's hard to make out, but when you look closely you can see it.
Did you guys have any problems with the clutch bells or the adjustment nuts on the shocks?
stefan is offline   Reply With Quote
Old 07-19-2011, 02:53 PM   #201
garen's Avatar
Zero issues on the dogbones and shock nuts on the RS (and all P81 series), and only one reported broken clutchbell.
Old 07-26-2011, 03:42 AM   #202
John Doucakis's Avatar
Originally Posted by John Doucakis View Post
New kit for sale, only done less than 2 liters on it.
JD RACING BLOG
Car is still up for sale.
I am droping the price
The price I am asking for the car, what you see in the first two photos in the following links, is EUR 300,00
http://data6.blog.de/media/698/5633698_e62051677d_o.jpg
http://data6.blog.de/media/697/5633697_ef20f937db_o.jpg
The price I am asking for all the spare and options parts as you see in the following four photos, is EUR 270,00
http://data6.blog.de/media/665/5633665_add0af1f99_o.jpg
http://data6.blog.de/media/667/5633667_54bbccb9d2_o.jpg
http://data6.blog.de/media/668/5633668_10b920d229_o.jpg
http://data6.blog.de/media/669/5633669_6624652ffe_o.jpg
Total is EUR 570,00 + Shipping cost EMS 5-7 days or registered mail 7-15 days.
I also have an RB C10 engine used for 3liters which I am selling for EUR 165,00 including exhaust pipe.
John Doucakis is online now   Reply With Quote
Old 07-26-2011, 01:07 PM   #203
garen,got my parts and found that i had the upper arms in the inner hole with the trimmed upper arm. i corrected that(eye sight is a prob at my time of life). i reset the camber at -2 degrees and what i find is that at full turn the axle pin is fully exposed. my width is 248/250mm. should i put a second washer behind the axle stub? i dont want to loose another axle and hub. they sent me plain steel axles(amain) i was wondering if the anodized ones are available. guess thats it and thanks again...
Old 07-26-2011, 11:16 PM   #204
FaanP's Avatar
The clutchbell on my RS broke as well - sheered of right behind the pinions - Replaced it with my old P81 clutch bell - no problems.
When in doubt - GAS IT!!
FaanP is offline   Reply With Quote
Old 07-27-2011, 08:53 AM   #205
garen's Avatar
A Main sent you the last of the gray dogbones as they probably had a mixed inventory.
How far are your wheels turning? If you have a setup fixture, the front knuckles should be turning around 28 to 30 degrees, no more. Also, where are you measuring the width. Make sure you are measuring from the outside bottom of the wheels. I normally run my car at around 248mm, but you should be able to run wider with no problems. If everything checks out and you still feel the pins are not all the way at full turn, install a second washer on the outdrive shaft.
Clutchbell: The one broken bell I have seen broke at the same place, but like I said before, only one reported broken.
Old 07-28-2011, 12:06 PM   #206
garen's Avatar
one more thing to try is to change the number of shims on the outside of the front axles, between the outer bearing and drive pin. Place only 3 washers outside and move the remainder to the inside.
Old 07-28-2011, 05:58 PM   #207
thanks i will check that out because it looks like the axle will still pop out...
Old 07-29-2011, 01:44 AM   #208
garen's Avatar
First batch of RS conversion/upgrade kits is here.
Old 07-29-2011, 11:09 AM   #209
pinoy69racer's Avatar
Trader Rating: 180 (99%+)
hi, Garen is there anyway that i can get or download the manual for conversion/upgrade kits.
HENRY C
DESOTO RACING/SERPENT/VEYTREX DESIGN LAB/RC TARGET
pinoy69racer is offline   Reply With Quote
Old 07-30-2011, 08:39 AM   #210
garen's Avatar
Yes, download the complete RS manual off either motonica-usa.com (support page) or motonica.com (download page).
