Old 03-11-2011, 08:52 AM   #136
stefan's Avatar
Send a message via AIM to stefan
We took the car to Fiorano two weeks ago and it ran awesome.
Really confidence inspiring handling.
We got to really good lap times really quick.
stefan is offline   Reply With Quote
Old 03-12-2011, 03:48 AM   #137
John Doucakis's Avatar
What set up did you use and what were the track conditions?
I still haven't managed to run mine..
John Doucakis is offline   Reply With Quote
Old 03-12-2011, 07:47 AM   #138
stefan's Avatar
Hi John,
I used this setup:
http://motonica.com/admin/uploads/SE..._RS-221210.pdf
Contact Tyres 32/35
Medium traction
fast flowing but also technical track
Blitz R11, 20mm from center of bumper
Old 03-13-2011, 03:09 PM   #139
the rest of my parts should be in this week, maybe get this finished for next weekend and get to do a shake down run. my buddy ordered the hudy set up kit so we can have fun trying to align this thing!!!! he ordered an xray,he didnt like the instructions for the p81rs and got nervous. now hes sorry because this car looks so good!!!
beaven is offline   Reply With Quote
Old 03-13-2011, 08:14 PM   #140
Default P81RS
P81RS with Evo4
MOTONICA P81RS-img_0403.jpg   MOTONICA P81RS-img_0393.jpg   MOTONICA P81RS-img_0392.jpg   MOTONICA P81RS-img_0407.jpg
stevenohk is offline   Reply With Quote
Old 03-14-2011, 08:42 AM   #141
NitroWD's Avatar
Default rear belt tension
any ways that we could increase/adjust the rear belt tension when using the 50T? seems like it's fixed at only 1 tension...slightly loose
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 03-14-2011, 11:32 AM   #142
stefan's Avatar
I am also new to this car, but I think there are special excenters for the 50 t rear pulley.
The part number should be MOT06183R02
Old 03-14-2011, 01:02 PM   #143
garen's Avatar
To use the 50T you must use either the aluminum cups shown in the above post, or use the new optional plastic cups included with the RS kit. The new plastic cups have an extra 'ear' on them and I think they are replacing the aluminum cups. Either way, the cups can be installed in various positions to gain or reduce tension and also raise or lower the spool. I used the new optional plastic cups, cut the extra ear off and lowered the spool and also put it at the highest tension setting. This is explained in more detail on the RS building tips. You can download the file on the support page of motonica-usa.com.
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 03-15-2011, 08:41 AM   #144
NitroWD's Avatar
Default rear belt loose
well, the rear belt still feel fairly loose even with garen's suggestion. won't it becomes more loose after running the car?
Old 03-15-2011, 10:59 AM   #145
garen's Avatar
Apparently not. Scotty ran the 50T at the KO race with no issues, and I have the 50T in my RS and at least through break in, no problems.
Old 03-15-2011, 12:39 PM   #146
romain_f's Avatar
In France we had the first round of our championship.
And Stephane Bouche with its Motonica P81 RS won the 45 min final.
HB R8/Novarossi
romain_f is offline   Reply With Quote
Old 03-20-2011, 03:50 AM   #147
NitroWD's Avatar
i've attached pictures of my rear belt tension, it's at the tightest setting, using 50T.
is it normal? i could 'press down' the belt about 10mm without much efforts needed...
Old 03-20-2011, 09:38 AM   #148
garen's Avatar
I am running my car with the 50T using the supplied plastic cups with the 3 ears. I cut one of the ears off so that I could rotate it to match the same position (both low and back) as the optional aluminum cups. The belt is not as tight as I would like or think it should be, but I have run all weekend without any problems. I will check to see if I can press down as far as you are pressing on your belt, but if you have not modded the cups like I did, you might want to do it.
By the way, this weekend at the RCX show race event Team Motonica has 2 cars in the expert field and at least 2 cars in the sportsman class. Both cars in the expert class are in the main, qualified 1st and 3rd and one car in the sportsman main, qualified 3rd or 4th. Brad Toffelmire has set TQ with his P81 Pro and I am 3rd first time out with my RS. Mains are today and I am heading out to the track soon, but it is raining here and likely going to rain out at the track too.
Old 03-20-2011, 10:51 AM   #149
stefan's Avatar
Guys, have you checked your dogbones yet?
Seems that we have quite a few that are cracked out of the box.
Old 03-20-2011, 07:29 PM   #150
NitroWD's Avatar
yup the rear is already installed as per your advices and suggestions...seems like the belt is having a tooth too many?
stefan: which dogbones and where they cracked?
