Old 07-13-2004, 07:49 AM   #1
mark123's Avatar
Default dish wheels
i got a question. what is so good about dish wheels?
mark123 is offline   Reply With Quote
Old 07-13-2004, 08:58 AM   #2
there cheaper
Mxracer1990 is offline   Reply With Quote
Old 07-13-2004, 09:00 AM   #3
PSI Racing's Avatar
They're usually stronger and more aerodynamic.
PSI Racing is offline   Reply With Quote
Old 07-13-2004, 09:01 AM   #4
r they like less wind resistant or anything
Old 07-13-2004, 04:46 PM   #5
Suspended
Send a message via AIM to RcRacerX
Lightbulb air head!!!
wind resistance is part of aerodymics.
RcRacerX is offline   Reply With Quote
Old 07-14-2004, 04:49 AM   #6
mark123's Avatar
ohhhhhhh ok i just thought there like that for strength.
thanks
mark
Old 07-27-2004, 09:40 AM   #7
R/C Tech Charter Subscriber
Default Re: dish wheels
Dish wheels are normally very strong, however they can be a little heavier. Also adjustments are a little more difficult as you will need to place holes into the rims or take them off for each adjustments.
But they are just as good as spoke.
www.twistertires.com
racinghobbies is offline   Reply With Quote
Old 07-27-2004, 09:58 AM   #8
BF
I have found any dish rims yet that aren't made of plastic instead of nylon. That means you can't recover the rims from worn out rubbers with acetone. Acetone turns plastic into toothpaste
BF is offline   Reply With Quote
Old 07-27-2004, 10:02 AM   #9
PSI Racing's Avatar
Try boiling the wheels to get the old tires off.
Old 07-28-2004, 04:51 AM   #10
mark123's Avatar
i tried doing the 'boil ur tyres off' trick but it doesnt work. i did it with this like very old wheel i had and i put it in boiling water and didnt really care wat happened to it. i then took it off after about 10-15 mins and it went all un-balenced and bent it some places. so now i will never do that trick again. or maby i just did it wrong..i just dont know.
Old 07-28-2004, 03:44 PM   #11
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i always use acetone to get old tyres off my wheels...and it never effects the wheel, well it hasnt yet
raving-monkey is offline   Reply With Quote
Old 07-28-2004, 10:58 PM   #12
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
get the speedmind dish rims, they are very strong. best you can buy. stay well clear of the yokomo ones. every one I bought eventually broke out in the center. 1 failed going around a corner, didnt even hit anything.
GrandeGixxer is offline   Reply With Quote
Old 07-30-2004, 01:18 AM   #13
Rapid Roy's Avatar
HPI makes nylon aero dish rims. Just make sure you get the black ones. The white ones are ABS.
Rapid Roy is offline   Reply With Quote
Old 07-30-2004, 02:26 AM   #14
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Default Tire
Where I can get just the tire that without rim. Thanks.
tkhoo is offline   Reply With Quote
5 sets of wheels/tires. slick, treaded, and drift. 4 dish wheels bionictony R/C Items: For Sale/Trade 2 07-12-2008 09:02 AM
Lot of Jaco 28mm Sedan Prism tires.28mm dish wheels. and 26mm wagon wheels. samstheman2 R/C Items: For Sale/Trade 15 11-23-2007 09:15 PM
Dish wheels or....... theChaz Rookie Zone 6 12-12-2003 01:11 PM
Tamiya TRF Blue Dish Wheels Brand new in package 8 wheels F/S reflekt R/C Items: For Sale/Trade 1 12-15-2002 01:52 AM
What dish wheels? Jared Kirkwood Electric On-Road 26 07-04-2002 12:50 PM
