Old 11-04-2010, 06:07 PM   #1
Trader Rating: 39 (100%+)
Default nitro handling help
i have a ntc3 and i am have a problem with the rear spinning out bad i run it in parking lot racing.Any help would be great thanks guys.
btown is offline   Reply With Quote
Old 11-04-2010, 11:13 PM   #2
Can you tell us the details of how it is setup?
Otherwise the first thing I would do is soften the springs, use softer wheels and add more toe-in in the rear.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 11-05-2010, 08:22 AM   #3
tony q's Avatar
I have NTC3 too, i set up my rear suspension soft for low bite traction and stiff for high bite, also try taking out sway bars in the rear if u have one. You mentioned u run it in the parking lot, dusty/dirty parking lot will have no traction also....
tony q is offline   Reply With Quote
Old 11-06-2010, 02:43 PM   #4
You're almost certainly running your rear diff to tight. Can't excatly rember what the manual recommends but slacken it off from book about a 1/10th of a turn more. Or looking at it as a clockface about 5 minutes. That should really help.
jonrg is offline   Reply With Quote
Old 11-07-2010, 05:23 AM   #5
The NTC3 uses a ball diff??
I thought it was a gear diff. Otherwise, make sure that the rear wheel turn freely when twisting them in opposing ways. if its hard to rotate them, that makes it slippery as anything. Make it softer using 10K weight or so.
Old 11-07-2010, 06:40 PM   #6
they still run the ball diffs
Capricorn LAB C-01 / RBtj 10 / Spectrum DX3
Roadrash730 is offline   Reply With Quote
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 09:27 AM
Converting 1/8 scale nitro buggy HELP WANTED rcCrafty Electric Off-Road 6 02-04-2010 04:43 AM
Going into 1/10th offroad nitro trucks ... help please ... Tabushi Electric Off-Road 19 11-30-2003 05:24 PM
