Old 11-02-2010, 09:11 AM   #1
Default Ball Bearings
I have seen racer that take out the seal from the Bearings and the car is very free rolling, does this mean they would ony last 1 race? and break faster??
jorge858 is offline   Reply With Quote
Old 11-02-2010, 09:12 AM   #2
1fastdude's Avatar
Trader Rating: 15 (100%+)
Yes, they are free-er, but will not last as long.......dirt and debree will get in the bearings and deteriorate them!
★RCAmerica •Xray •Hudy •BSR •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is online now   Reply With Quote
Old 11-02-2010, 12:23 PM   #3
gfilos's Avatar
if you want more rolling, get metal shields bearings. Using the bearings without seals will ruin them in no time.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 11-02-2010, 12:54 PM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
You can do this at the wheel axles. Put the open side to the inner side of the upright and not much dirt wi;; come in, you can even use a small piece of schrink wrap between the bearings to cover the sleeve for the pins of the dogbones
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 11-02-2010, 01:05 PM   #5
simplechamp's Avatar
Trader Rating: 73 (100%+)
Try bearings that have a rubber seal on one side and metal shield on the other. The rubber seal faces outward to better protect against dirt and debris, and the metal shield is safe facing inward, and offers less resistance.
Serpent 811Be - Jammin X2 Carbon e-GT conversion - Axial SCX10 Honcho
simplechamp is offline   Reply With Quote
Old 11-03-2010, 05:16 AM   #6
blis's Avatar
here's my cleaning tips:
I remove my rubber seals, I also remove metal ones but they can be a painful exercise.
A friend gave me a handful of plastic specifmen jars and I drilled out holes in one and trimmed it so it would fit inside the other. This allow debris to fall thru the holes. I use kerosene to clean them and rinse.
Then depending on bearing I attach some fuel line to my dremel and for bigger bearings I use the soft pad and I spin them up in a small amount kerosene just to flush out the rest of the debris.
Then I use food grade inox to insert grease into them. My theory is that as the bearing spins it melts the grease it needs to and creates a wall of grease so debris sticks to it and not the balls.
Time consuming and well worth the effort.
PS: Take note that the seals I wipe clean carefully not to damage them and I dont soak them in kero or they expand.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Cleaning ball bearings? JSY Rookie Zone 19 08-19-2016 06:55 AM
Benefit of ceramic ball bearings and diff balls RCSteve93 Electric On-Road 23 09-02-2008 03:34 PM
Ball Bearings in a Stock Motor - why aren't they legal? or8ital Electric On-Road 60 04-24-2007 11:21 AM
Cleaning ball bearings D_o_S Electric On-Road 35 12-13-2006 06:35 AM
Ceramic Ball Bearings uniquexme Nitro On-Road 21 11-14-2006 11:37 AM
