Old 11-01-2010, 09:58 PM   #1
Default Dull pipe help !
I have a OS T-2040, after the race and I wanted to clean it back to its shiny original condition. I used some grease remover, and the Chromed finish turned very dull ! I tried polishing it but to no avail. Any help or I will have to stay like this forever ?
AdrianOngs is offline   Reply With Quote
Old 11-02-2010, 05:51 AM   #2
jakerz's Avatar
get some Mothers Mag and Aluminium Polish
http://www.mothers.com/02_products/05100-05101.html
Use a Dremel on low speed with a felt polishing wheel. This should get the shine back.
In the future, when you want to clean a pipe, fill a cheap crock pot with green antifreeze, throw the pipe in, turn it on low and let it simmer for about 8-12 hrs. make sure you dont ever use the crock pot for food as it will not be ruined by the antifreeze.
jakerz is offline   Reply With Quote
Old 11-02-2010, 03:17 PM   #3
This works like a charm. I've recently brought a few pipes back to life using the this process.
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Old 11-02-2010, 03:24 PM   #4
Trader Rating: 47 (100%+)
Your best bet is to buy another pipe just like the ome
you have now. Use one to race with and the other
to look at when it's sitting on the shelf. I honestly
like seeing a car with a dull pipe and some rubber
dust all over it. That way I can tell it's not a self-queen.
rageworks is offline   Reply With Quote
Old 11-02-2010, 04:26 PM   #5
Trader Rating: 18 (100%+)
Default dull pipe
You should also try Jassco paint stripper. You can get it at Home Depot.
Brush it on, wait about 10 min. rinse it off, and then polish the pipe with Mothers aluminum polish.
Works like a charm, and is very fast acting.
Another way is to use Carbon Off. You get this at Smart and Final.
Spray it on, rinse the pipe, and polish.
I use both methods, and either one works great, and takes very little time
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 11-03-2010, 09:59 PM   #6
Thanks guys !
Murnan Modified Motors Grinder Onroad Nitro Engine Zone 3810 10-13-2017 12:46 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 02:13 AM
help with backyard 1/18 offroad tack mamba4life Micro and Mini Scales 94 08-19-2011 03:05 PM
