Old 07-12-2004, 04:34 AM   #1
Quietroit's Avatar
Default Setup For A Nitro Tc3
HELP NEED ON A SETUP FOR A SHORT TRACK FOR MY NTC3. THE TRACK SOME BUMPY , TRACTION IS MEDIUM, COMPOSITION IS ASPHALT. THEY DON'T PUT SUGER WATER OR VHT JUST BLOW IT OFF ON RACE DAY. NEED SETUP ON SPRING, TOWER MOUNTING, CAMBER LINK, ARM NOUNTING, PISTONS,SHOCK OIL,TOE-IN, RIDE HEIGHT,CAMBER, CASTER,AND DROOP.
Quietroit is offline   Reply With Quote
Old 07-12-2004, 06:38 AM   #2
soc123_au's Avatar
R/C Tech Charter Subscriber
Rubber or Foam Tyres?
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 07-12-2004, 08:53 AM   #3
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Setup For A Nitro Tc3
here is one for a bumpy track:
Old 07-12-2004, 02:35 PM   #4
intimidator's Avatar
hey marcos,your in tampa huh,im from tampa,used to race alot getting back in the swing now.like to put a face with a name,i prolly know you already if you been around,you go to speedline?you know george at pitstop,or ever go to the track at the airport in lakeland?greg at farmers?
intimidator is offline   Reply With Quote
Old 08-08-2004, 01:05 AM   #5
Send a message via AIM to JDMboy
Question on baker's clutch shoe set up
what do they mean by cut shoes or not?
i see he has cut checked?
i just upgraded my set up with the 3 shoe conversion adn AE copper stiffer slutch springs
can someone please explain the cutting part? where and how to? and gains in performance with this?
thanx
JDMboy is offline   Reply With Quote
Old 08-08-2004, 06:50 PM   #6
mxs
By cutting the shoes you can change a point when the clutch will engage. The lighter the shoes are the later it will engage meaning the RPMs will be higher which usually means a quicker take off. some people would drill little holes in them others would shave off a little of each shoe. Don't forget there's no way back, so shave off very little at a time and make sure it's the same on each shoe.
Or if you have the money buy a Centex clutch.
If you are new and you are not looking for the very last edge over other racers I wouldn't worry about it too much. There's tons of stuff you can do to improve your car.
Also it depends what engine you have. Not every engine will be ok with such a clutch adjustment.
mxs is offline   Reply With Quote
Old 08-11-2004, 12:53 AM   #7
SCIDA's Avatar
Are you running the new rear end or the old one?
SCIDA is offline   Reply With Quote
wtb nitro touring setup tony montana R/C Items: Wanted to Buy 2 06-09-2008 04:25 PM
What would be a good nitro setup for me? racingboy14 Nitro On-Road 8 03-15-2008 10:02 AM
MBX5R NITRO PIT SETUP donbeatya Nitro Off-Road 0 02-11-2008 05:31 PM
almost prospec mbx5 f/t with engine for nitro touring setup or electric setup tony montana R/C Items: For Sale/Trade 13 02-03-2006 12:42 PM
setup for a nitro tc3 Quietroit Nitro On-Road 2 07-12-2004 09:00 AM
