Old 07-11-2004, 12:08 PM   #1
Default Return spring
I have an impulse pro that I need to put a return spring on.I'm not allowed to use a rubber band it must be a spring.I have a airtronics 94358 servo that seems a little stiff but works great.Any ideas or pictures that you guys have would be great ..
fasteddie d is offline   Reply With Quote
Old 07-11-2004, 02:01 PM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Return spring
i placed my return spring from the servo horn on the brake side to the radio plate screw near the front right upper arm,
Old 07-11-2004, 08:33 PM   #3
Return spring on a 94358 isnt that kind of pointless...
vadn1 is offline   Reply With Quote
Old 07-11-2004, 08:53 PM   #4
tomkelley's Avatar
MOST hobby shops carry throttle return springs. Team Losi makes a good one and its about 3 bucks. You could use a spring ment for a exhaust manifold too, you just hook one side to the chassis and the other to either the horn or the carb. Depending on the rules, you will have to mount it to the carb if it is a ROAR rule or the opposite side of the horn (if its on the horn it could be bad if the carb linkage pops off). Exhaust springs might be too much tension, so I just get the Losi one.
Good thing they make you use throttle return, I've seen too many runaways and its usually because they don't require it.
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
Old 07-13-2004, 02:10 AM   #5
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Default Can't
Look like we can't pun the TRS on digital servo........it will stay there if Rx battery in low.
For me I put digital servo on the steering and analog servo on throttle.
tkhoo is offline   Reply With Quote
wanted jr xr2i trigger return spring nitrs4rcr2 R/C Items: Wanted to Buy 4 05-26-2007 08:21 PM
Throttle return spring 4 8ight-T with Axial Tony899 Electric Off-Road 4 04-08-2007 05:12 PM
Team Losi Throttle Return Spring for LST Cain R/C Items: Wanted to Buy 2 10-28-2005 11:02 AM
NTC3 nitro throttle return spring ideas for slide carb motors? calstarjig90j Nitro On-Road 5 09-13-2004 10:56 PM
return spring help savage 2mcgrath Monster Trucks 3 02-12-2004 09:55 PM
