Old 10-19-2010, 02:04 PM   #1
Default Jato Big Block Project lots of pics
Building a Jato and Planning on bumpstarting it with a .21 o.s. v-spec. going to be used for on-road only
Today went well, bought the new era big block kit from my LHS and went to work, accompanied the kit with a Tony's screws set due to having multiple stripped screws when i got the jato. Also bought nice fancy exo-c/f side mud guards. Went to work on the dissasembly and was real easy. When time came to take apart the rear i noticed oil everywhere, so i took apart the rear diff to find a broken seal and no diff oil. So another trip to the LHS and bought the rear driveshaft kit, which came with all the seals i needed. Finished up the install and did not have a motor to put in, since my v-spec is out getting worked on. So i had a mach 427 without the p/s (getting pinched at rayaracing) so i put it in as a test fit, the back plate for the rotor start did not fit and if that were the motor i was using i would need to modify the chassis, i plan on bump starting the motor so this is no problems, just put in the motor as a look to what it will be like, i'll also have to get the entire clutch assembly and trim the body to fit the v-spec when i get it, heres tons of pics.
anthonys88 is offline   Reply With Quote
Old 10-19-2010, 02:05 PM   #2
gotta figure out an exhaust setup also
Old 10-19-2010, 03:08 PM   #3
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Looks nice
But you could use the stock chassie ,i have done a few Jatos with the Picco 26 pretty fast just have keep the front wheels on the ground.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 10-19-2010, 03:14 PM   #4
yeah, but it was scratched and this one is stronger and lighter.
Old 10-19-2010, 03:38 PM   #5
ALLSPEED's Avatar
please get a vide befor you shred the tranny. lol
Kyosho evolva M3 EVO O.S. .21xzr? Xray NT1 murnan modded nova,Xray T3,AE T5, sc5m, b44.3,Tekno sc
Mugen 1/8 off road.Tekin esc's, smc batts, team powers motors a winning combination
ALLSPEED is offline   Reply With Quote
Old 10-19-2010, 03:48 PM   #6
i was planning on it
Old 10-20-2010, 06:37 PM   #7
http://www.youtube.com/watch?v=Y447HilQ9L0
still have to find a motor, exhaust that actually fits, and gearing. this video was just a teaser and slapped together parts
Old 10-24-2010, 10:47 AM   #8
Old 10-24-2010, 08:26 PM   #9
got some more work done today, officially fitted the motor into the jato. its a stock v-spec with a freshly pinched p/s so it'll need a break in. 20/40 revo gearing. had to do some modifications for it to work, but it fits nicely now. Ordered a traxxas 2.4 tq link radio system on ebay due to the factory one kind of glitching at around 100 ft. Will need only an exhaust and starter box to be complete. heres the pics. btw the head of the engine is off of a speed v-spec.
Old 10-24-2010, 10:36 PM   #10
td-civ's Avatar
Trader Rating: 18 (95%+)
very nice gob
td-civ is offline   Reply With Quote
Old 10-24-2010, 10:42 PM   #11
Trader Rating: 20 (100%+)
You said it's on road, but you got mud guards?
quixoticboi is offline   Reply With Quote
Old 10-24-2010, 10:58 PM   #12
they look nice, got a problem just incase a pebble or something does not get up into the gears i guess.
Old 10-24-2010, 10:59 PM   #13
Haha. I know. Carbon fiber is always nice.
Old 10-24-2010, 11:01 PM   #14
i'll probably end up ditching them, depending on how the exhaust fits we'll see.
Old 10-27-2010, 08:55 PM   #15
there going to officially be taken off, set the starter box without them, exhaust would not fit also. btw this is not the exhaust going to be used. its going to be an 1.8 scale on road setup, pipe was rigged to break in the motor only
