Old 07-04-2004, 05:54 PM   #1
rcracer14's Avatar
Send a message via AIM to rcracer14
Default Sirio .12 Turbo
I was wondering if someone could give me a good overall setting for the Sirio .12 turbo. I keep on using up plugs like no tomorrow and it doesn't run for the entire race (about 5-6 minutes). Any help would be awsome.
rcracer14 is offline   Reply With Quote
Old 07-04-2004, 06:38 PM   #2
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
what wrong with your plug?? too wet??
tkhoo is offline   Reply With Quote
Old 07-04-2004, 07:34 PM   #3
rcracer14's Avatar
It might be that. Because one day the glow pug worked and then died, then the next day it worked again. I'll lean it out some.
Old 07-04-2004, 08:13 PM   #4
tkhoo's Avatar
Default retune
Maybe you can return your engine...........rich up high and low end. Start from low end.......lean it by 1/8 a time and make sure check the temp every time u lean. After very good accerelation and the temp are in the spec than set the high needler.
Old 07-04-2004, 08:26 PM   #5
Trader Rating: 52 (100%+)
does this motor have no bottom end or what, I run on a tight layout and cant seem to get any punch out of it, it has rpm like noones buisness but no snap, and my clutch is fine
any help is great
thanks
Mo
Mo Denton is offline   Reply With Quote
Old 07-04-2004, 08:49 PM   #6
tkhoo's Avatar
is your low end too rich?? I hear that sirio is a good engine.
Old 07-04-2004, 08:54 PM   #7
rcracer14's Avatar
I found that messing around with the low end needle and finding the perfect setting is the best way to do it. If you have a centax try loosening it up.
Old 07-04-2004, 08:58 PM   #8
I starting setting the low end and ended up at one point with it all the way in and stll no punch, I am runnign the three show clutch with cut shoes.
Mo
Old 07-04-2004, 09:03 PM   #9
rcracer14's Avatar
I have it 3 1/2 turns out, but it will probably be different with a three shoe clutch, but you might as well try it anyway. Make sure you're adjusting the needle that is in the throttle slide.
Old 07-04-2004, 09:08 PM   #10
whats your high end and mid range set at, my factory settings were all jacked up
thanks
Mo
Old 07-04-2004, 09:18 PM   #11
rcracer14's Avatar
Well I have my highend at 5 1/4 turns out but it's running really rich so I'd say you should put in 4 3/4 and then if you need to lean it in a little more. As for my mid needle thats the one thats 3 1/2 turns out.
Old 07-04-2004, 09:20 PM   #12
tkhoo's Avatar
Don't adjust the mid needler. Just adjust it flat with the carb body if you have adjust it.
Old 07-04-2004, 09:26 PM   #13
rcracer14's Avatar
Can you tell me so I know for sure which needle is the mid needle and where it is.
Old 07-04-2004, 09:29 PM   #14
tkhoo's Avatar
can I have your email address.........I send u the pic.
Old 07-04-2004, 09:31 PM   #15
I had the mid needle 3 turns out I will try 3.5 out and see when we were taking it out it was getting better but ran out of daylight, and if its flush with the carb body its all the way screwed in.
thanks
Mo
new trinity g4 pro w/sirio turbo fasthpir40 R/C Items: For Sale/Trade 27 12-13-2004 02:43 PM
Sirio 5-Port Turbo .12 blue dragon R/C Items: For Sale/Trade 3 08-01-2004 01:42 PM
sirio .12 turbo 5 ports 1.6 hp. elephant R/C Items: For Sale/Trade 7 05-18-2004 06:05 AM
smeltz sirio .12 w/ turbo & non turbo head brand new! d.a.d.d.4 R/C Items: For Sale/Trade 25 04-27-2004 07:56 PM
Sirio .12 Turbo ACC sleeve Roger R/C Items: For Sale/Trade 3 03-20-2003 11:16 AM
