Xray RX8 1/8th Scale >
Like Tree5Likes
Old 05-04-2014, 01:35 AM
  #1111
reracer's Avatar
Sorry, quick question. What's the diameter of 1/8 scale tires? Do they need to be trued, or can you run them out of the box?
reracer is offline
Old 05-04-2014, 11:47 AM
  #1112
djiewie's Avatar
The 7mm split is important to have steering otherwise just true for purpose like quali`s and finals regarding timelapse.
djiewie is offline
Old 05-04-2014, 08:33 PM
  #1113
OnRDPassion's Avatar
Trader Rating: 56 (100%+)
Where I run I like using 67 mm for the front and 74 mm for the rear.
OnRDPassion is offline
Old 10-26-2018, 10:15 PM
  #1114
Question, I have a 2013/2014 model I believe. I’ve seen set up sheet that show spur gears are 45/49. Newer models show 55/59 on the newer models.
Why such a huge difference between model year?
Any my issues with my 2013 running 55/59?
Thank you.
DK9mm is offline
Old 10-27-2018, 10:06 AM
  #1115
Roelof's Avatar
The older has modul-1 teeth (bigger) The newer has modul 0.8 teeth (smaller). There is no reason to switch to the smaller teeth unless you can not get the bigger ones anymore.
davidl likes this.
Roelof is offline
Old 03-05-2019, 06:35 PM
  #1116
1/8 IC Fan's Avatar
Trader Rating: 95 (100%+)
I wanted to ask, is anyone running the Chassis Balancing weights PN# 309840? If so, do you find they may interfere with the Throttle Servo body at all?
1/8 IC Fan is offline
Old 03-05-2019, 06:39 PM
  #1117
And where is the best place for weights to help balance the car? I have a 2013.
Thanks.
DK9mm is offline
Old 03-05-2019, 06:49 PM
  #1118
1/8 IC Fan's Avatar
Thanks.
The weights I was asking about were on the new 2018 car as it is slotted for them. I know on our 2013 it is not slotted, but we have run the brass lipo tray and front brass insert.
Old 03-07-2019, 08:22 AM
  #1119
Originally Posted by djiewie View Post
What i have been doing with my clutch the last 4 years racing is the following.
Put the new clutch shoe in an oven and bake it for 20minutes in 200 degrees.
The yellow clutch shoe from the xray nt1 lasted me a very long time with awsome cluth. very consistant and fast accelerating. Consistant because the clutchgap stays the same without much wear. No need for any run in whatsoever.
now i have the Serpent 977, been doing first what the guys told me and had problems. changed to my baking method and lost the clutch problems. All smiles again.
Worth a try and keep it secret so you gain an advantage
i use hard springs though
have fun.
200C degrees or Fahrenheit?
evox88 is offline
Old 04-24-2019, 09:51 AM
  #1120
Philly basher's Avatar
Sup fellas I just grabbed my first rx8 nitro but I don’t plan on using it for track racing, just parking lot bashing. Has anyone used a standard clutch setup on these instead of the centax clutch? I know centax is great for racing but I’m just bashing with it. It’s just a matter of getting the flywheel to align for starter box & gears to align/mesh correctly right? Appreciate any help
Philly basher is offline
Old 06-13-2019, 07:28 PM
  #1121
Trader Rating: 42 (98%+)
I am not sure you can use anything else, It not hard to setup. You just have to make sure there is not too much gap between the clutch bell and the clutch.
wichitafc98 is offline
Old 06-30-2019, 07:39 AM
  #1122
Are there any Clutch springs than the ones that are in the stock RX8.2 kit?
Old 07-13-2019, 07:23 PM
  #1123
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
Hi Can someone explain what is a reversed clutch and how it differs from the regular ones thanks
Tag is offline
Old 07-16-2019, 03:09 AM
  #1124
~McSmooth~'s Avatar
It means the flyweights on the clutch are oriented in the “reverse” direction. This arrangement allows the clutch to engage at at a slightly lower rpm.
~McSmooth~ is offline
Old 07-16-2019, 03:54 AM
  #1125
Roelof's Avatar
With the old clutch the fly weight will move forward over the pin while moving out due the centrifugal forces. Because it will not be in a straight line the movement will have some friction making the clutch less smooth and loosing force.
With the reverse clutch the position of the fly weight will stay put on the pin and will only rotate. No friction so much smoother. And because the movement is in a straight line on the rotation it will create maximum force to keep the clutch tight. With that you can engage on a higer rpm range and still have no slip.
Roelof is offline
