Old 07-05-2012, 06:50 PM   #1006
asw7576's Avatar
Originally Posted by beebone View Post
Yes I did, I use Mugen clutch as well, but using Serpent shoe cos mugen shoe is shit. I also mod the 2 speed with Mugen set
hey beebone, i want to see how do you manage to use mugen 2speed? Are you using parts from mrx4 or mrx5?
photo please.
Old 07-10-2012, 03:35 PM   #1007
photo please.
I'm now using new style Xray cluch. So I can tell the mod instruction.
- bore the Mugen 2 speed adaptor pin area to fit original 3mm pin, remember don't over-bore that area. Buy any 3mm pin to cut and fit to Mugen adaptor
- shim the 2nd gear around 1mm between the 2 speed housing and the gear
- buy some 8mm x 0.1mm shim to shim between 1st and 2nd gear if any free play
- All are MRX5 parts
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 07-10-2012, 08:27 PM   #1008
Trader Rating: 4 (83%+)
beebone why are you using a mugen 2-speed on your X-ray ?
Shepherd Micro Racing @ Novarossi @ Matrix Tires @ VP Fuels @ Nugget Racing
Roniel_R is offline   Reply With Quote
Old 07-10-2012, 08:28 PM   #1009
asw7576's Avatar
oh i see...... Thanks beebone.
Old 07-18-2012, 02:59 AM   #1010
asw7576's Avatar
Hello friends,
What car handling effects do i get :
when i install wheel axle shims ( 1mm + 1mm + 1mm ) on the outside, ie. wider front track width
and
when i install wheel axle shims on the inside, ie. narrower front track width.
My goal : I need more steering off throttle...... undesteering problem off throttle
Thank you friends
Old 07-18-2012, 03:55 AM   #1011
Roelof's Avatar
Send a message via ICQ to Roelof
More shims outside will give more on-throttle steer.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 07-18-2012, 04:05 AM   #1012
asw7576's Avatar
I see ......... Thanks roelof.
Old 07-18-2012, 09:08 AM   #1013
pinoy69racer's Avatar
Trader Rating: 180 (99%+)
Default if anyone is interested
http://www.rctech.net/forum/r-c-item...-1-8-road.html
HENRY C
DESOTO RACING/SERPENT/VEYTREX DESIGN LAB/RC TARGET
pinoy69racer is offline   Reply With Quote
Old 07-18-2012, 02:35 PM   #1014
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Originally Posted by pinoy69racer View Post
let me know
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 07-18-2012, 07:27 PM   #1015
Erock's Avatar
[QUOTE=asw7576;10987401]Hello friends,
and
Thank you friends [/QUOTE
You can also add caster for more mid to exit steering.
Hobbytown USA, Byron's Fuels, RC America, Clints creations paint, KO ProPo, Kevco racing, Picco engines, Matrix Tires
Erock is offline   Reply With Quote
Old 07-18-2012, 10:42 PM   #1016
asw7576's Avatar
Hi erock,
Thanks for the advice .
My problem is off power understeering... It turns wider than another rx8.
( I think because I use 2mm longer screws to make my car stronger, the downsides are stiffer and heavier car, it weights 2450 grams race ready )
ON power steering is fine.
Old 07-22-2012, 03:33 AM   #1017
Hi guys,
Whats a cmpatiable set of shocks from another brand of car for the rx8? Mine leak after one meeting and the pivot arms always slip wheb changing piston holes. Does anyone know if mugen or capricorn 1/8 shocks are the same lengths?
Thanks in advance.
Capricorn LAB C02
Protoform
Futaba
Sirio
xray man is offline   Reply With Quote
Old 07-22-2012, 04:08 AM   #1018
josecarlo1129's Avatar
Originally Posted by xray man View Post
Hi guys,
Thanks in advance.
Try Motonica's.
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 07-22-2012, 07:50 AM   #1019
asw7576's Avatar
Hi guys,
Thanks in advance.
I am using mugen mrx4 front shock damper. Fit very nicely in rx8. Don't forget to replace / enlarge the piston hole. 1.5 or 1.3 mm. I also replaced the membrane with tamiya low profile membrane. Low profile membrane don't collapse and produce minimum rebound.
Old 08-07-2012, 12:34 AM   #1020
Thanks for the replies. Ill have to look into it.
Any thoughts on the reverse clutch 2012 edition? How does it Perform?
Capricorn LAB C02
Protoform
Futaba
Sirio
Xray 808 E-Conversion Kit? Dookiman Electric Off-Road 467 04-26-2013 03:42 PM
