Old 04-08-2012, 05:47 PM   #976
Sterlzy's Avatar
Trader Rating: 29 (100%+)
Hey guys,
Just waiting on my 2012 kit. What clutches/ clutch set ups is everyone running? I know they are a big thing in on road. Any help would be awesome
KYOSHO, PROLINE, REDS, MKS SERVOS, KO PROPO, VP POWERMASTER, BITTYDESIGN, PLAIG BEARINGS.
WWW.BENSTERLING-RC.COM
Sterlzy is offline   Reply With Quote
Old 04-08-2012, 07:11 PM   #977
Send a message via AIM to jeff whiting
Default Loran"s RX8 2012
Almost done with Loran's new ride with a little APlus action.
Xray RX8 1/8th Scale-rx8-2012-2.jpg   Xray RX8 1/8th Scale-rx8-2012-1.jpg
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 04-08-2012, 08:34 PM   #978
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
nice a+ also nice touch
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 04-09-2012, 08:47 AM   #979
Originally Posted by xray man View Post
Hi,
Will be buying the 2012 upgrade. Does anyone know if the new clutch works? Or is it as bad as the first? Had big problems with it not engaging and the clutch spring self tightening half way through a heat?
Just break in the new clutch today, the flywheel is 6 kg lighter than mugen, the rest of weight are same as mugen. Just do some breakin of the bell and shoe, very grip.
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 04-09-2012, 09:08 AM   #980
Originally Posted by Sterlzy View Post
Hey guys,
Follow the standard, 0.7mm bell clearnace and 0.5mm preload for washsers.
But make sure the engine nut is 14.2mm one, not 13.8mm (NT1). I mess it up and set preload in 0.5mm, the car can't launch.
Old 04-09-2012, 09:11 AM   #981
u will impress for the handling on 2012
Old 04-22-2012, 03:06 PM   #982
Does anyone happen to know where it is possible to purchase the XRay RX8 2012 kit? I've found the 2012 conversion, but I'm hoping to get the kit with all the 2012 parts. I've looked and haven't found it so far, I'm guessing it hasn't been released yet. I'm aware I can just purchase the 2011 kit and purchase the 2012 conversion, but it'd be cheaper to compra el coche completa. If anyone happens to know of any online store it may be hiding at, let me know because Google refuses to.
SUPERFORMIAN is offline   Reply With Quote
Old 04-22-2012, 05:47 PM   #983
YLLIB's Avatar
www.acornracingusa.com has them in stock, they specallize in 1/10 & 1/8th on-road nitro.
YLLIB is offline   Reply With Quote
Old 04-23-2012, 12:25 PM   #984
Send a message via MSN to Sonter
Default Clutch help
Hello Friends, could anyone tell me what I am doing wrong with the clutch! I have removed the stock spring clutch and installed the conical washers but the clutch seems not going out too much to make contact with the bell. Any help please?
Sonter is offline   Reply With Quote
Old 04-23-2012, 06:16 PM   #985
Sounds like you have the clutch bell shimmed too far away
I have seen Ralph Burch drive an RC car, It was an amazing thing to watch. So I joined his team and got the same car... XRAY and RC AMERICA
CFowler is offline   Reply With Quote
Old 04-23-2012, 11:00 PM   #986
Angry
I just built it as the manual says. I built it several times to make sure that I did it right. Do I have to put more conical washers so it could go out more? I measured all the washers and the stock spring, and the spring is longer than all of the washers. Can't understand what I am doing wrong
Old 04-24-2012, 04:35 AM   #987
asw7576's Avatar
Make sure the bearings inside the clutchbell is push inward, I mean the bearings are seated at maximum depth inside the clutchbell.
Tips : Use after run oil to lubricate inside the clutchbell where the bearing sit.
Clutchbell <<<< 5x10 bearing <<<< 0.2mm shim <<<< 5x12 bearing <<<< 0.2mm shim or whatever thickness in here <<<< centax engine locknut
Old 04-24-2012, 05:30 AM   #988
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Clutch using washers setting is different to spring, and most likely is the clutch gap cause you problem since washer dont have that much movement like spring
for washers setting I first measure the flywheel nut cause there is 2 different length nut and that will dictate how your tension measurement, if you have 13.9mm nut then screw the spring cup nut to 0.6mm and set the gap to 0.3mm - 0.35mm with small amount of end play, clutch bell has to spin free.
This will be the base setting for conical washer. Play around tension and gap to suit your track condition
tl2111 is offline   Reply With Quote
Old 04-28-2012, 05:27 AM   #989
I am installing 1mm shim between bearings, as manual says. Do you think that my problem is this?
Old 04-28-2012, 07:28 AM   #990
Roelof's Avatar
Send a message via ICQ to Roelof
For 12 washes setting the clutch to 1mm gap each washer just need a movement of 0.08mm and believe me, they can. You have to think one thing different, you do not need a lot of pre-tension. Just screw the nut against the washers so they are locked up without a tension, from there you just need an half to max 1 turn to get the right clutch.
You can run normal gap settings of about 0.7~0.8mm as most drivers are used to have.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Xray 808 E-Conversion Kit? Dookiman Electric Off-Road 467 04-26-2013 03:42 PM
