Old 10-12-2011, 11:31 AM   #826
Dasmopar's Avatar
Send a message via AIM to Dasmopar
Originally Posted by Darint View Post
I'd recommend narrowing the rear track width, take each side in 1mm, (2mm more narrow in the rear).. This will help the car rotate going in, and provide more grip on throttle/exit.
hmm. My car is set up pretty wide. I will have a look at that tonight.
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 10-12-2011, 11:33 AM   #827
Dasmopar's Avatar
Originally Posted by CFowler View Post
My home track is Ft Myers. I am currently running 800 oil with 3 hole in the front. 600 with 3 holes for the rear. I have the 7.0 front springs and I switched from the red springs to the XRAY 6.3 springs on the rear. If you would like to see it I would either post or send you my set up sheet.
Im assuming that you have all roll centers in the stock positions, axle positions, extra chassis weights that kind of stuff.
Send it to me or post it and we can exchange notes. I have my roll centers moved from the kit settings.
Lon Burling II
Old 10-13-2011, 08:02 AM   #828
RC MARKET's Avatar
Arrowmax released Alum. Belt Pulley
Xray RX8 1/8th Scale-am-rx8-345820.jpg   Xray RX8 1/8th Scale-am-rx8-345858.jpg
RC MARKET is offline   Reply With Quote
Old 10-13-2011, 11:58 AM   #829
Dasmopar's Avatar
Anyone found a good alum. servo arm for the steering servo? Spectrum/KO
Lon Burling II
Old 10-13-2011, 12:56 PM   #830
Roelof's Avatar
Send a message via ICQ to Roelof
Xray and Robitronic have servo horns which are mounted with 2 screws. one on top as every other and one at the side as a clamp.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 10-13-2011, 02:17 PM   #831
Send a message via AIM to jeff whiting
We are using the KO servo horn. We got them from Drew. As stated above it is also the clamping syle and also uses a screw as normal. Very nice piece.
Jeff
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 10-13-2011, 02:29 PM   #832
Hudy for me
I have seen Ralph Burch drive an RC car, It was an amazing thing to watch. So I joined his team and got the same car... XRAY and RC AMERICA
CFowler is offline   Reply With Quote
Old 10-13-2011, 02:59 PM   #833
File is too big to post send an E-mail address and I'll send set up sheet
Old 10-14-2011, 10:33 PM   #834
Dasmopar's Avatar
Dasmoparatyahoodotcom
Lon Burling II
Old 10-15-2011, 12:52 PM   #835
Sent
Old 10-16-2011, 09:52 PM   #836
Dasmopar's Avatar
Sent
Thank you!
Lon Burling II
Old 10-18-2011, 06:26 AM   #837
Alex C's Avatar
Trader Rating: 50 (100%+)
Thank you!
Your Welcome
How you and Jeff doing ????? itching to run some 1/8 Scale I'm sure!!!
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 10-18-2011, 11:11 AM   #838
Dasmopar's Avatar
Originally Posted by Alex C View Post
Your Welcome
We are both doing ok. I'm itching to race something. I hung out at the track sunday just to be around it. F1 cars are on the way I think. What are you up to?
Lon Burling II
Old 10-19-2011, 10:19 AM   #839
sultan's Avatar
When will the rx8 2012 spec be out ??
sultan is offline   Reply With Quote
Old 10-19-2011, 10:35 AM   #840
Dasmopar's Avatar
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
Dasmopar, hobbs, ToysRUsKid
My man crush----^^^^^^^----is in here too!
Lon Burling II
Xray 808 E-Conversion Kit? Dookiman Electric Off-Road 467 04-26-2013 03:42 PM
