Old 09-27-2011, 08:20 PM   #811
advfuel's Avatar
Trader Rating: 29 (100%+)
Originally Posted by wingracer View Post
How much gap is there between your flywheel and the engine? If you have a fat collet, it can push the flywheel out farther making it difficult to get a proper gap.
I machined down the collet so I could get the 9.2mm measurement from the end of the crank shaft to the tip off the fly wheel nut. I havent got the engine here at work, but it is close, like 1-2mm.
The only thing I havent done is measure the crankshaft length, and compare with another engine the same, but I couldnt see there being much difference between engines
Cheers Wingracer
advfuel is offline   Reply With Quote
Old 09-27-2011, 11:33 PM   #812
Cheers Wingracer
Ok here you go i had the same issue trying to get gap in the clutch bell. I ended up finding out off a friend that the bearings both big and small are installed from the engine side of the clutch bell with the 2 x .5mm shims in between. As soon as i did this i had miles of play to shim so all good.
I did look at the instructions 20 times and for some reason it did not register in my head to do it this way, i am used to the kyosho clutch bell were one that bearing is installed from the rear and the other from the front.
i hope this helps.
Mike Schroder is offline   Reply With Quote
Old 09-28-2011, 06:34 PM   #813
advfuel's Avatar
i hope this helps.
Well Mike, dont I feel like a knob . You are 100% correct. Every clutch I have also built has 1 bearing from the engine side and 1 from the front. Clutch is all good now.
Thanks Mike
Old 09-28-2011, 07:36 PM   #814
Thanks Mike
Dont worry so did I
Glad i could help.
Old 09-28-2011, 08:31 PM   #815
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Thanks Mike
so what are you doing with the 966 clutch ? both bearings sit inside the bell with the spacer in between the bearings ??
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-28-2011, 11:22 PM   #816
advfuel's Avatar
Remember I keep complaining Im going thru clutch bearings and I had problems setting it up, well the plot thickens. Now I feel like a even bigger Knob. Maybe they should manufacture them so there idiot proof .
Ha patto you never stop learning, Building the mugen clutch for so long I just never changed my habbits
Old 10-04-2011, 11:05 AM   #817
RC MARKET's Avatar
XRAY released Alu Brake Disc Belt Pulley
Xray RX8 1/8th Scale-xr-345920.jpg
RC MARKET is offline   Reply With Quote
Old 10-11-2011, 10:55 AM   #818
Dasmopar's Avatar
Send a message via AIM to Dasmopar
Push going in, loose coming out.
We battled with this all weekend last weekend. I ended up running like 2º toe in per side on the rear trying to get the car to turn in. The result was a car that had to be pretty much pointed straight before getting back on the throttle. Kyosho front bar flat, rear blade type bar at 45º or more. 2º total toe out in the front. 909 body with very little wing. 32, 35 shore tires in a few different brands. Any ideas?
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 10-11-2011, 11:01 AM   #819
Send a message via AIM to jeff whiting
Change the Driver.
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 10-11-2011, 11:11 AM   #820
Default Loran's set up
Lon,
Seriously though, I thought Loran’s RX8 was pretty good at the Snow Ball race with good steering and rear grip. I will copy the setup down and post it here in a few days. Might help and at least useful as a reference.
Jeff
Old 10-11-2011, 03:17 PM   #821
What springs ya running ?? Sounds to me like you need to stiffen the rear springs, soften the front springs. The rear blade at 45 !! thats stiff !!
Check your front belt or side belt and see if its slips or jumps
I have seen Ralph Burch drive an RC car, It was an amazing thing to watch. So I joined his team and got the same car... XRAY and RC AMERICA
CFowler is offline   Reply With Quote
Old 10-11-2011, 10:58 PM   #822
Dasmopar's Avatar
Xray red rear (600 2 hole), and 7.0 in the front (900 3 hole). No belt issues. This was two cars doing the same thing with two different drivers. My car works very well on sealed asphalt but un-sealed seems to be my issue. The car jjst never turns enough for my taste and my next race is the Winter nats.
Lon Burling II
Old 10-11-2011, 10:59 PM   #823
Dasmopar's Avatar
Originally Posted by jeff whiting View Post
Change the Driver.
Jeff has the same issue so we sorta did change the driver. Maybe I need to turn Foster loose with it?
Lon Burling II
Old 10-12-2011, 08:29 AM   #824
I'd recommend narrowing the rear track width, take each side in 1mm, (2mm more narrow in the rear).. This will help the car rotate going in, and provide more grip on throttle/exit.
www.RCAmerica.com - XRAY - HUDY - Max - JACO - KO PROPO
Darint is offline   Reply With Quote
Old 10-12-2011, 09:03 AM   #825
My home track is Ft Myers. I am currently running 800 oil with 3 hole in the front. 600 with 3 holes for the rear. I have the 7.0 front springs and I switched from the red springs to the XRAY 6.3 springs on the rear. If you would like to see it I would either post or send you my set up sheet.
Im assuming that you have all roll centers in the stock positions, axle positions, extra chassis weights that kind of stuff.
Xray 808 E-Conversion Kit? Dookiman Electric Off-Road 467 04-26-2013 03:42 PM
