Old 09-15-2011, 08:47 AM   #796
RC MARKET's Avatar
Free Replacement Clutch spring for RX8 Customer
#348540 RX8 Conical clutch washer spring set
Xray RX8 1/8th Scale-xr-348540-replacement.jpg
RC MARKET is offline   Reply With Quote
Old 09-15-2011, 11:22 AM   #797
Dasmopar's Avatar
Send a message via AIM to Dasmopar
Does this mean they showed up?
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 09-22-2011, 01:16 PM   #798
God I've been looking at both the RX8 and the NT1 and was thinking about getting an NT1 especially since its $150 cheaper and also cuz it has a tank measure for it to show how much fuel's left in the tank. You can get a lot of upgrades for both, but I think I'll get the RX8 cuz I've never had a pan car before. And if I really wanted one before, I wouldn't get a Nugen or Kyosho. They're not me, they don't fit me. The RX8 is perfect. I have to say that this may be the most expensive nitro car I'll ever buy after all the upgrades, electronics, engine, and muffler. Gotta get one!!!
SUPERFORMIAN is offline   Reply With Quote
Old 09-25-2011, 10:37 PM   #799
advfuel's Avatar
Trader Rating: 29 (100%+)
Default Clutch
Can someone be kind enough to give me an idea on what clutch parts they are using for the RX8. Im using a Novarossi 25-21 engine and having difficulties setting the gap as it just tightens up on the shoe when doing up the bell bolt. I have tried the mugen collar which is longer but still no good. I have been reading thru the forum pages but cant find a solution.
Cheers
advfuel is offline   Reply With Quote
Old 09-25-2011, 11:44 PM   #800
asw7576's Avatar
Cheers
I dont know the length of your cranskshaft tip.
Normally you need to add shims between flywheel locknut and clutchbell bearing.
However, If your crankshaft tip is not long enough, there is a chance the thrust bearing will be over pressed as you tightened the last bolt. In this case you have two options :
1. change to longer tip of thrust bearing stopper ( in this case i use mugen seiki thrust bearing stopper )
2. add shims between xray thrust bearing stopper and crankshaft tip. Keep adding shims until the clutchbell can move very freely with slight amout of lateral gap.
tip: use longer bolt screw when using longer thrust bearing stopper or adding shims
Old 09-25-2011, 11:53 PM   #801
advfuel's Avatar
Thanks for your reply. Yep thats exactly what I did, I used the mugen thrust bearing stopper but still had to add 2.7mm shims under that.
Just making sure Im not doing any thing silly
Thanks again.
Old 09-26-2011, 08:40 PM   #802
Default NEw Xray disc washer
Anyone install the washer disc in the clutch yet?
I've found the instruction is wrong, when all 6 pcs 0.6mm washer and 6 ocs 0.4mm washer stack together, it's too high. when turn the spring hat in 0.5mm as intrsuction mentioned, the washers have no room to move.
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 09-27-2011, 01:19 AM   #803
rc-goods's Avatar
Default CSO RX8 7075 T6 Hardcoated Lightweight Clutch Bell (RX-8024)
www.rc-goods.com
Xray RX8 1/8th Scale-cso-rx-8024_l_wm.jpg
rc-goods is offline   Reply With Quote
Old 09-27-2011, 02:23 AM   #804
MrUnlimited's Avatar
Free? That is what we like to hear!
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 09-27-2011, 08:58 AM   #805
Dasmopar's Avatar
Jeff Z and myself both ran the Bellville warshers at the Nats. We both set the clutch up at 0.5mm and 0.5mm with a brand new Xray yellow shoe and the waRshers stacked up per the directions. Neither of us had any issue at all with the clutches. My clutch had more rip than the old set up. Jeff qualified 9th and I was 14th in a fast feild so the clutch works! My shoe is nice and golden brown now over the full contact surface which i was never able to get before.
Lon Burling II
Old 09-27-2011, 09:08 AM   #806
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
thanks for letting me sit next to you guys
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 09-27-2011, 09:10 AM   #807
Dasmopar's Avatar
Thanks for not sitting on my lap more than a few times. It was nice meeting you.
Lon Burling II
Old 09-27-2011, 10:20 AM   #808
Tried serveral times the clutch can't engage with 0.5 preload, the hat pressed all the washer together got no room to move as per instruction. T_T
Old 09-27-2011, 12:07 PM   #809
What is your gap?
If mine gets up to .6 preload it gets funny, but .5 seems to be good.
it would seem this spring, takes a little less gap for the same feel.
My cone setup .5 and .5 felt like the Xray hard spring @ 1.1 and a .7 gap
Jeff Z
Desoto Racing, Serpent America, Novarossi, KoPropo, Xceed.
2011, 2013, 2 Time Midwest Series 1/8th Open, Champion
2011 Byrons onroad 1/8th Open 3rd
2011 Roar Nats 1/8th Open, 5th
2012 GLC 1/8th Open Q7 Finish 5th, 2013 GLC 1/8th Open Q4 Finish 7th
Vector03cobra is offline   Reply With Quote
Old 09-27-2011, 12:27 PM   #810
wingracer's Avatar
Trader Rating: 24 (100%+)
Thanks again.
How much gap is there between your flywheel and the engine? If you have a fat collet, it can push the flywheel out farther making it difficult to get a proper gap.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Xray 808 E-Conversion Kit? Dookiman Electric Off-Road 467 04-26-2013 03:42 PM
