Old 08-19-2011, 02:56 AM   #781
Originally Posted by jrice View Post
I used the blitz body last weekend . worked very well. car was balanced
also.
Try some tight corners, u will know what i mean
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 08-19-2011, 02:58 AM   #782
Originally Posted by bigredspeed View Post
Beebone when you say don't use the blitz body because it wont turn? what do you mean it wont turn? i have been using the Blitz R11 and the car turns fine?
Some bodies made the car understeer.
I tried 909 on RX8, tried different roll center and distance from centre of bumper. still understeer.
But R15B, no special setup it can turn in any tight corners.
Old 08-21-2011, 02:24 AM   #783
bigredspeed's Avatar
Thanks for that Beebone. can i ask how much distance you were running using the P909? i am getting some to try out also, i also have the R15 that i am in the process of cutting out and getting ready for test also..
look forward to your reply mate
Alex
Tornado Racing Fuel and Product
Sanwa
XRAY RX8,ZAC OS SPEED XZR
XRAY X12,Muchmoore Fleta
Hudy, HEI international
bigredspeed is offline   Reply With Quote
Old 08-21-2011, 09:00 AM   #784
Alex
-909, 23-28mm, but I think its too forward
-R15B, 15-20mm. If you rise the rear roll centre, so make it 15mm.
Old 09-02-2011, 11:17 PM   #785
rc-goods's Avatar
Default CSO RX8 Alu 7075 T6 Lightweight Front Upper Arm Holder (RX-8023K)
www.rc-goods.com
Xray RX8 1/8th Scale-cso-rx8-acso-rx8-alu-7075-t6-lightweight-front-upper-arm-holder-rx-8023k-_wm.jpg
rc-goods is offline   Reply With Quote
Old 09-10-2011, 09:33 AM   #786
Trader Rating: 14 (100%+)
Conical clutch spring upgrade:
http://www.teamxray.com/teamxray/new...affef58f100e26
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 09-10-2011, 07:59 PM   #787
Erock's Avatar
Originally Posted by thunderbt3 View Post
No thank you..LOL my stock clutch works great. Using Orion spring though.
Hobbytown USA, Byron's Fuels, RC America, Clints creations paint, KO ProPo, Kevco racing, Picco engines, Matrix Tires
Erock is offline   Reply With Quote
Old 09-11-2011, 04:35 AM   #788
Roelof's Avatar
Send a message via ICQ to Roelof
The funny thing is that more and more brands do come with these springs while some people are convinced it does not work:
http://www.rctech.net/forum/onroad-n...ch-spring.html
The quality of an answer comes with the quality of the question.
Roelof is online now   Reply With Quote
Old 09-11-2011, 08:05 PM   #789
First race of the season, tried some new spring combinations
7.0 front spring
6.3 Rear spring
Adjustable rear sway bar (15 degrees)
very balanced car with plenty of steering
I have seen Ralph Burch drive an RC car, It was an amazing thing to watch. So I joined his team and got the same car... XRAY and RC AMERICA
CFowler is offline   Reply With Quote
Old 09-13-2011, 10:27 AM   #790
I have Pirani clutch disc spring in 0.6/0.4mm thickness. Tired the Pirani recommended setting in 0.6)0.4(0.6)*(*)*(*)*(*)*(*)*( , the spring is 0.5mm tension, it works fine with yellow clutch shoe.
But I tried the Xray setting in 0.6)0.6( ..... 0.6(0.4)0.4(.....04.( , 0.5 tension as well, the car can't lauch with yellow shoe. I think this is for red shoe only.
Old 09-13-2011, 11:09 AM   #791
Roelof's Avatar
The stacking of the discs should not matter how it is done, only the amount of each is making the tptal spring. In my topic I have a link to an interesting document how to calculate the stacking of different springs and to me it seems it may not make a difference how the discs are placed as long they are serial stacked ()()()()().
I can imagine the thinner discs will work more so the diameter will go larger (going from an angled shape to more flat). When some of those 0.4mm discs are placed in the spring nut or in the shoe adapter and they do fit tight they do not have the room to work well and will be blocked, the left over discs with all the fee space will give a higher spring tension.
Old 09-13-2011, 12:37 PM   #792
Dasmopar's Avatar
Send a message via AIM to Dasmopar
This is going to add a hole new level to the clutch set up. Get your pens and paper ready once we all get our hands on them.
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 09-13-2011, 08:37 PM   #793
Yes, I think so, I've found out I tight it too much, no room to let the discs work. Is it just tight the hat and secure the discs? No need to tight too much?
Old 09-13-2011, 08:39 PM   #794
Tired with Pinari discs long time ago, but the only problem is the spring hat lossing always, in fact, the hat should be applied thread lock but I didn't =P
Old 09-14-2011, 12:38 AM   #795
Roelof's Avatar
My experience is that you do not need to set a lot of pre-tension
Xray 808 E-Conversion Kit? Dookiman Electric Off-Road 467 04-26-2013 03:42 PM
