Old 08-01-2011, 09:26 AM   #736
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Originally Posted by ToysRUsKid View Post
car look beautiful.
Ditto...
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 08-01-2011, 07:11 PM   #737
Alex C's Avatar
Trader Rating: 50 (100%+)
Originally Posted by Dasmopar View Post
I saw the 3 radio trays you had in your feng shui pit area 2 weekends ago. Looked like graphite termites had taken up refuge in there. lol
This is very true, however since and I quote "I am still a Newbee in this realm of On Road 1/8 Scale" and a bit out of my element .
I still plan to overcome and succeed in doing better each outing with the car. Hope to see the rest of the boys from Ohio in the near future ............ Best Regards!!!
Alex
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 08-01-2011, 11:30 PM   #738
Dasmopar's Avatar
Send a message via AIM to Dasmopar
Alex
You look better and better. I see flashes of speed from you. you just need to string them together is all. Are you coming to Cincy for the midwest series race next weekend?
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 08-02-2011, 12:17 AM   #739
Default RX8
Hi guys,i will be getting the RX8 soon and i will be racing for the remaining of the club races.so,i just wanna ask how does this car handle and feel compared to the other cars like say the Mugen?and any tips while building up this kit or any additional option parts needed?any help is appreciated.thanks!
tq23 is offline   Reply With Quote
Old 08-02-2011, 05:26 AM   #740
asw7576's Avatar
Im building it right now............
The manual book is perfect, it is very easy to read and understand. All plastic and allumunium parts required no sanding ....... everything are perfect fit .
My tips : re-lube all the bearings !! Use small safety pin or acto knive to peel off the seal. Do it slowly and carefully.... and dont forget to relube them plenty with tamiya ceramic grease.
Small bearings are very hard to peel off, so dont peel it off. I just soaked the small bearings in small container with bearing oil.
Performance : Same as good as mrx5 ........... my friends who race with rx8 are happy with xray rx8. Ditto with my friends who race with mrx5. Both are fast cars.
Reliability : rx8 is stronger ( more durable ) car than mrx5.
Sucks : xray original clutch shoes are so expensive and dont last long...... so mostly we use kyosho evolva clutch shoe, ..... kyosho clutch shoe is cheaper and more durable. ( but it need re-drilling the holes ).
Old 08-02-2011, 09:36 AM   #741
choisan's Avatar
May try the latest mugen clutch, but u still have to try your luck of the original xray endbell, need to run in. But good luck of running it in.
choisan is offline   Reply With Quote
Old 08-02-2011, 09:58 AM   #742
Wrong offset with the Xray gears, I tried.
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 08-02-2011, 10:22 AM   #743
Roelof's Avatar
Send a message via ICQ to Roelof
Simply solved by making other engine mounts with the right offset.
I have done some (fast) comparing and if you use the Mugen engine mounts and only screw it on the screw holes close to the flywheel the Mugen clutch seems to come in line.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 08-02-2011, 10:29 AM   #744
YBSLOW's Avatar
We sell brass and aluminum versions of these that fit the mugen offset clutch.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 08-02-2011, 10:58 AM   #745
MAD916's Avatar
No need for special mounts. we just placed 2mm or so worth of shims behind the pinion gears on the Mugen clutch bell and it lines up perfectly... all three of our RX8's here are running the shimmed out Mugen clutch. think the shim is like 10x15mm... I got mine from my Align Trex Helicopter parts but think it's a pretty common shim.
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 08-02-2011, 12:21 PM   #746
How do you put 2mm shims behind the pinion gears?
raceblast is offline   Reply With Quote
Old 08-02-2011, 12:40 PM   #747
YBSLOW's Avatar
You actually would have to put 3mm worth of shims behind the flywheel to get the correct spacing, but that is placing the weight alot further out on the crankshaft, but it will work. Just not the way I would do it.
YBSLOW Racing
Old 08-02-2011, 01:58 PM   #748
After Sunday practice I found out a minor scratch in the xray red clutch shoe surface. Any suggestions?
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 08-04-2011, 05:42 AM   #749
Tony Rice's Avatar
Our new cars are in town and on the truck for delivery
Xray RX8 1/8th Scale-xray.jpg
______________________________
Shepherd USA RED CUP RACING DeSoto Racing Nova Rossi Byron Fuels winternats.com
Tony Rice is offline   Reply With Quote
Old 08-04-2011, 09:17 AM   #750
NEver try this flywheel shim, unless u got Colari 35 plus with the long cranksahft, otherwise, its only limited space to shim the bell gap and endplay.
I shimed the flywheel with Nova F21 PT, the clutch gap only 0.4mm left.
Xray 808 E-Conversion Kit? Dookiman Electric Off-Road 467 04-26-2013 03:42 PM
