Old 06-28-2011, 09:08 AM   #676
Send a message via AIM to jeff whiting
Originally Posted by tonyhalandri View Post
The car works great straight out of the box have you change anything on your set up?
Yes we did run a setup that was quite different than the stock setup. I know Xray is working on getting the PDF RX8 setup sheet ready for distribution but I will see if I can put something together, scan it to PDF and post it here or on the teamxray.com forum.
Jeff
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 06-28-2011, 09:36 AM   #677
Originally Posted by Erock View Post
Just a little build tip. Put a 3x12 grub screw in the front arms for the lower shock mount instead of the 3x8 that come in the kit. I had one on each side want to pull out at the Byron's race this weekend without any impacts. Love the car. Thanks Drew for the help this weekend!
Yes, the grub screw is too short, in fact, the depth inside the arm should be more than 8mm. The longer screw, more secure for the lower shock ball link.
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 06-28-2011, 10:24 AM   #678
MAD916's Avatar
Had a good weekend with the RX8 and am now incredibly impressed on how tough the car is. Had (2) separate head on full throttle hits this weekend in the A-main, had a couple different cars flip onto the straight right in front of me and plowed into them I mean full throttle. it actually survived the first hit with some the setup gone and tweak but not so bad, only to get it again about 5 laps later which was a total blow out.
But we are only talking shock cap, shock tower, front arms, front bulkhead, and bumper mounts, not as bad as I was thinking when it happened... you should see my body WOW.
SO one tough mother, the chassis looks fine, as well as most everything else.
Needless to say we will be putting the metal dividers back in (it's just easier to mow without them) for the TZGP, and the RX8 is getting all fluffed up and will be ready to rock........................
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 06-28-2011, 11:33 AM   #679
Default Loran's 2011 Byron's setup
Here is the setup we used at the Byron Challenge. I would say this set up would not be great for low or medium traction tracks since she had lots of steering. I drilled the top of the front shock at the base of the eyelit with a 1mm hole to vent the shock above the membrane and did not run the foam in the front shock. An offroad trick I know but it makes the front feel very linear. Remember this (or any setup) setup is not going to be perfect for everyone but should be useful as a reference. And...this was our second race with the RX8 too so take this all with a grain of salt. Have fun.
Old 06-28-2011, 11:58 AM   #680
asw7576's Avatar
Anyone know the length of rx8 front lower hinge pins ?
(part number 34 7210 )
Thank you
Old 06-28-2011, 12:56 PM   #681
Thank you...the thing is to understand your thinking when you change the car set up depending on the track...
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 06-28-2011, 01:37 PM   #682
Good question. I am sure there are many thoughts on this subject. Experience is important for sure but to me you must have a goal when setting up the car. For instance, the first time we ran the RX8 with the stock set up we noticed a lack of low speed steering and the rear was too planted and would not rotate well. So I knew it needed more front grip and less rear grip. So I changed the front and rear roll centers and the springs to get the handling I was looking for. Hope this helps a little.
Jeff
Old 06-28-2011, 04:16 PM   #683
Hey Jeff, BIG high 5 to Loran !!! She was awesome !! Great Job
Makes me glad Im running in the old timers class!!
Looked at your set up, noticed that you do not have any weight added and you were running the aluminum motor mounts. Did your car weigh out correctly ?
You know Im new to the RX8, but everyone is telling me that I have to add weight.
Chris
I have seen Ralph Burch drive an RC car, It was an amazing thing to watch. So I joined his team and got the same car... XRAY and RC AMERICA
CFowler is offline   Reply With Quote
Old 06-28-2011, 04:34 PM   #684
Chris
no tech at that race i was told
DESOTO RACING--SERPENT-977 EVO- 2010/2017 FORGASS -PRES.
RED CUP RACING - -BYRONS FUEL -NUGGETS RACING- RC AMERICA
PICCO RACING ENGINES - SANWA RADIOS - - -http://winternats.blogspot.com
FORT MYERS R/C CAR CLUB MEMBER 1983-2017--FLORIDA WINTERNATS 1988-2017
jrice is offline   Reply With Quote
Old 06-28-2011, 07:05 PM   #685
Chris, Jim is right the Byron's is a TFZ race (Tech Free Zone). We ran the car the way it came plus the regular weight 909 body so it prolly was right at the legal minimum with big tires. I'm with ya Chris...long live the Masters class. BTW way I have my RX8 sitting on its wheels so it won't be long for me.
Old 06-28-2011, 07:38 PM   #686
YBSLOW's Avatar
Wit a nimh battery, 75g copper battery tray and 75g brass motor mounts, I still have to add another 100g to get legal?
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 06-28-2011, 08:12 PM   #687
Ouch...ok then we ran light......TFZ Good thing I have a your tray, brass motor mounts, unniversal weight kit to install and we run a nimh. Always something to think about for next time. Thanks Brad.
Old 06-28-2011, 08:39 PM   #688
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
we weighed mine without a lipo 2200 grams, shes LIGHT for sure....
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 06-29-2011, 07:32 AM   #689
YBSLOW's Avatar
Haha........too funny, when in in Rome, do as the Romans do.
I will have the brass radio tray mounts probably done by this weekend as well.
YBSLOW Racing
Old 06-29-2011, 09:49 AM   #690
Yes, mine hit the pit lane twice, still able to run the rest of the tank.
Xray 808 E-Conversion Kit? Dookiman Electric Off-Road 467 04-26-2013 03:42 PM
