Old 06-07-2011, 06:58 AM   #586
choisan's Avatar
aren't xray having the alloy options yet?
if not, they will have it for sure. they won't let go to make any high price options.
choisan is offline   Reply With Quote
Old 06-07-2011, 07:52 AM   #587
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
Originally Posted by jeff whiting View Post
We finally got to run our RX8 this past weekend at the Midwest Series Race in Portage Indiana. Loran had never run 8th scale before but the car made it look almost easy. I used the kit set up except I used a yellow clutch shoe. The car was pretty good right out of the box. This was a parking lot track so I think softer springs would help it a little but all in all we are very impressed with the car. I asked Loran how she liked 8th scale and her comment was "it's awesome". Next up the Byron Challenge.
Loran make any car look easy ...she a great driver!!!!
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 06-07-2011, 08:05 AM   #588
Originally Posted by beebone View Post
Anyone? I found the concentric and eccentric bushing melt, the wheel axle losing, anyway to keep the bushing cool? The bearing I think too hot during the race.
I checked mine, they're fine after ~3 gallons on the car. It must be seized bearing, same thing happened to my NT1 eccentric (one that goes into ft. bulkhead) when bearing seized and overheated.
*gk* is offline   Reply With Quote
Old 06-07-2011, 03:19 PM   #589
All bearings are brand new and smooth
beebone is offline   Reply With Quote
Old 06-07-2011, 03:41 PM   #590
Send a message via AIM to jeff whiting
Use R15B body, you don't have to worry about the handling.
I use the Mugen grey on front and Xray Red (hard) at rear same on bumpy track. Fantastic with R15B body!!!
That sounds about right for the spings. Thanks for the input. And I will check out the R15B body. We ran the old 909 this past weekend and it seemed pretty good.
That's nice of you to say. If I can keep on top of the set up for her, I think she will do well at the Byrons.
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 06-07-2011, 08:30 PM   #591
YBSLOW's Avatar
Default Mugen offset motor mounts
We finally have more of the Brass motor mounts with Mugen offset, as the first batch sold out in 1 day. We have them in 70-75 aluminum now as well.
Xray RX8 1/8th Scale-rx8_brass_motormounts_web-1.jpg
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 06-08-2011, 07:34 PM   #592
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
for the guys who mounted the throttle servo as pictured on box, did u flip the servo horn around as well<as shown in pic as well> lastly, why exactly did u do this, thanks
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 06-08-2011, 08:03 PM   #593
Alex C's Avatar
Trader Rating: 50 (100%+)
Default RX 8 Shock Question??
For those of you that have built your kits with the plastic shock bodies, I have a few questions.
  1. When building your shocks have you drilled a .8mm hole on the plastic piece to eliminate any issues with rebound??
  2. Have most of you utilized the foam inserts??
  3. If not drilling any holes in any of the shock ends, approx. what would be the most effect rebound setting utilized.
Any further insight as to the questions above would be greatly appreciated .................... Thank You All Again !!!!!
Alex
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 06-09-2011, 09:14 PM   #594
Alex
Just wondering why to eliminate any rebound?
Old 06-09-2011, 11:03 PM   #595
asw7576's Avatar
Too much rebound is bad thing..... the car handling become loose, but I dont know the exact reasons.
Watch how quick the shock shaft does rebound..... the shaft should rebound very slowly..... about 4 seconds for the shaft to reach full rebound.
Old 06-09-2011, 11:36 PM   #596
what my corncern is the rebound amount, not the rebound speed. The shock can be always set my ideal rebound ver well with no issue.
I set 25% rebound, just bleed the excessive oil from bottom.
Old 06-11-2011, 04:34 PM   #597
Default rx8
Originally Posted by RC America View Post
Good catch! I missed that field when transferring the info.
There is a 2mm shim. The rear shock pistons should also be two hole, not three.
I will edit the sheet when I get back to work this morning.
- Bryan
- Update: Setup sheet in previous post edited with info above.
thats a 2mm shim under the rear outside hubs, where the upper camber link attaches to, place a 2mm under there? also on the front droop is it 0 or 2? please confirm, thanks
Old 06-11-2011, 08:03 PM   #598
Default Shocks
Alex C
If you get the chance, download the XRAY setup guide for the NT1 (I haven't seen one for the RX8, yet), however, if you go to the teamxray.com website and download the NT1 Setup manual, you'll find in the last few pages (I think it's page 38), it discusses Shock Rebound and why..
http://www.teamxray.com/teamxray/pro...0&catName=XRAY NT1 World Champion Limited Edition
If I remember correctly, it suggests higher rebound for lower grip tracks, and lower rebound for higher grip tracks.
Hope that helps,
www.RCAmerica.com - XRAY - HUDY - Max - JACO - KO PROPO
Darint is offline   Reply With Quote
Old 06-11-2011, 08:28 PM   #599
Alex C's Avatar
Originally Posted by Darint View Post
Alex C
Hope that helps,
Darint,
Thank You Again for the information...................... Best Regards!!!
Alex
Alex Cortez
Old 06-13-2011, 09:06 AM   #600
RC MARKET's Avatar
ARROWMAX
Alum 7075 Pulley
Xray RX8 1/8th Scale-am-rx8-345888.jpg
RC MARKET is offline   Reply With Quote
Xray 808 E-Conversion Kit? Dookiman Electric Off-Road 467 04-26-2013 03:42 PM
