Old 05-16-2011, 04:27 PM   #526
Had my first proper race with the RX8 last weekend, which was in the British National series rd 2 at Wombwell and I seem to be the lone Xray runner amongst the entries. Im only an midfield runner so qualified for the C final and finished 4th in that final ( I should also mention it was my first visit to this particular circuit so had to learn the track which is the most technical here in the UK together with variable weather/track conditions ).
The car started from the default setup sheet but after the initial practice run we dialled in 4 degrees of rear camber, changed to the floating rear radio tray buttons and changed the 1st spur gear to a 50 tooth cog. This felt good with plenty of front end steering and rear end stability on 35 shore tyres all round. My car has still got the modified to fit Serpent clutch shoe installed with a .5 clutch gap nothing else different in the clutch and that ran the whole weekend without faults and without having to touch it at all. In fact the car ran totally reliable all weekend, nothing broke or fell off, or wore out even though we unintentionally tested its strength against various barriers a number of times during the event.
Absolutely love the car, many thanks to Juraj Hudy / Xray for designing and producing an 1/8 circuit car that is a pleasure to run.
Serpent 966TE , GRP .21, Picco 2033 Tuned pipe, Futaba 3GR 2.4ghz, SRC Zytec v2 shell
eigthracer is offline   Reply With Quote
Old 05-16-2011, 04:40 PM   #527
Originally Posted by tonyhalandri View Post
My advise is to follow the xray clutch tip and see the performance before you use any other spring.
Yes, thats what I did, set the clutch and break-in in original parts.
I changed the spring in Mugen hard, Xray hard spring is too short and the collar will lose always
beebone is offline   Reply With Quote
Old 05-17-2011, 08:53 AM   #528
princessmocha's Avatar
Hi,just started building rx8!!!do you guy thinks the springs between the brake pads is abit too stiff and put too much load on the throttle servo??
princessmocha is offline   Reply With Quote
Old 05-17-2011, 09:27 AM   #529
YBSLOW's Avatar
Nope
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 05-17-2011, 09:51 AM   #530
so you have only change the spring?Nothing else?
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 05-17-2011, 11:22 AM   #531
DS Motorsport's Avatar
Default Capricorn Clutch for the RX8
For anyone who is experiencing clutch issues with the RX8, now there is a proper clutch available from Capricorn.
With this you're able to use the original Xray pinions but get the superior performance from the Capricorn clutch.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 05-17-2011, 08:08 PM   #532
After break in with original spring, I change spring into Mugen hard.
Xray hard spring is too short. Nothing else
Old 05-17-2011, 08:15 PM   #533
Default Encentric wheel bearing housing
Still waiting for the set up book, I know the purpose for the front encentric housing to push the front wheel forwrd to gain more caster.
But no idea about the rear, only involve the roll center adjustment? Any idea?
Old 05-17-2011, 09:51 PM   #534
Both front and rear upright eccentrics are there to adjust wheelbase in addition to moving arms
*gk* is offline   Reply With Quote
Old 05-18-2011, 12:49 AM   #535
What exactly does on the rear eccentrics? lower/forward means lower roll center and reduce wheel base?
Old 05-18-2011, 12:53 AM   #536
Roelof's Avatar
Send a message via ICQ to Roelof
You can set the ride height without affecting the setup. When setting the rideheight with the spring collar you will change several settings like camber and rollsetting.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 05-18-2011, 01:29 AM   #537
oic, thanks! What if I want the tail becoming lose, move the eccentric up and forward?
Old 05-18-2011, 02:29 AM   #538
Roelof's Avatar
I would say less toe-in, lower the rear body/spoiler and play with the rollcenter settings.
Old 05-18-2011, 06:30 AM   #539
YBSLOW's Avatar
Default YBSLOW BRASS MOTOR MOUNT
75g
Xray RX8 1/8th Scale-rx8_brass_motormounts_web-1.jpg
YBSLOW Racing
Old 05-18-2011, 10:29 AM   #540
less rear camber,put some shims below rear upper arm,move rear absorbers to the upper holes....in general higher the rear rollcenter
Anyone knows when we put shims in the front sevro saver's linkage(outer position to the hubs)?
Xray 808 E-Conversion Kit? Dookiman Electric Off-Road 467 04-26-2013 03:42 PM
