Old 07-04-2004, 06:33 AM   #1
rjl
rjl's Avatar
Default Best Trick Part
What's the best value trick bit that you have found?
The best thing I've found is Kawahara wheel nuts, they never come loose and they don't seem to wear out.
The GPM exhaust springs are about the best I've used.
You know those little box wrenches you get? I have one that came with a Marui Big Bear that refuses to wear out, the one part that didn't.
rjl is offline   Reply With Quote
Old 07-04-2004, 06:36 AM   #2
intimidator's Avatar
my favorite trick part on my ride are those silver body clips.
intimidator is offline   Reply With Quote
Old 07-05-2004, 09:03 AM   #3
Taylor-Racing's Avatar
The best trick part I found was to use "O" rings instead of those squishy silicone exhaust gaskets. They last for ages.
. . must get some more of those.
"Marui Big Bear"
Taylor-Racing is offline   Reply With Quote
Old 07-05-2004, 09:48 AM   #4
Sow&Steady's Avatar
"Marui Big Bear"
Now that is the best one I've heard ever! Having seen o-rings that does not even change shape up to 350 DegC, let alone melt, I'm wondering why I never thought of doing the same as you Taylor-Racing.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 07-06-2004, 07:16 AM   #5
BrainTeased's Avatar
i agree very very good idea about the O ring seals.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 07-06-2004, 04:39 PM   #6
PSI Racing's Avatar
"Marui Big Bear"
Can you post a pic of that?
Do you just put an "O" ring on instead of the gasket?
PSI Racing is offline   Reply With Quote
Old 07-06-2004, 05:29 PM   #7
you would think that your header would touch inside where the exhaust outlets inside it,it would probbly seal it but your gonna have metal to metal somewhere.unless they manage to stay perfectly aligned.unless you put a smaller o-ring on the inside?
Old 07-07-2004, 01:38 AM   #8
HELLION's Avatar
Default Best trick part!
I think this is the best trick part!!!
HELLION is offline   Reply With Quote
Old 07-07-2004, 01:45 AM   #9
Sorry, I'm without a digicam but have attempted a pic below.
I just use two different types/sizes of "O" ring.
Two of the small 1.8mm section black ones ("Nitrile", I think) and a larger 2.6mm section orange one at the base of the exhaust outlet. This one is "Viton", if I recall, but I could have the two materials mixed up.
Anyway the smaller ones prevent the metal to metal contact mentioned and the larger one takes the compression forces from the exhaust spring.
The "O" rings are particularly tough and you can happily use two manifold springs that would normally just separate the flange part from a normal gasket in a couple of heats.
They are still affected by fuel etc. but last a whole lot longer than the normal silicone ones. I buy these at any local bearing supply and they're a few dollars for a handfull.
Old 07-07-2004, 01:47 AM   #10
Oooop's . . here's the pic.
Old 07-07-2004, 01:52 AM   #11
Obviously having trouble posting a pic, here.
Old 07-07-2004, 01:57 AM   #12
rjl
rjl's Avatar
You still using that other computer Gav?
Old 07-07-2004, 01:59 AM   #13
Hmmm, can't seem to upload a file here.
Yes, I know how to do it.
Anyone want to PM me their e-mail address so you can post it?
Cheers, Gavin
Old 07-07-2004, 02:02 AM   #14
Oh, you mean the thinking mans OS.
Old 07-07-2004, 05:39 AM   #15
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Default RPM BUMPER
my RPM bumper....
its tough! really tough.
after a crash still alive. no bend or something!
mop
mop_iko is offline   Reply With Quote
Any V2 motor tip & trick? James khoo Electric On-Road 11 12-21-2006 10:22 PM
TRICK 05 XRAY!!!!! Factory Seal R/C Items: For Sale/Trade 3 11-14-2006 02:20 PM
TRICK 05Xray Factory Seal R/C Items: For Sale/Trade 2 11-13-2006 12:41 PM
trick mini-t cody branam R/C Items: For Sale/Trade 4 10-09-2006 10:05 AM
i need part number to this hitec part TomB Electric On-Road 2 05-23-2006 08:58 AM
