Old 07-11-2004, 09:06 PM   #31
Best tric part Kyosho rims they are awesome much better than anything else I've seen and are in fact cheaper than most. I have only buckled one rim ever and all my set of rims have had a few sets of tyres which have been driven for liters and liters of fuel untill the tyres fall apart.
frozenpod is offline   Reply With Quote
Old 07-11-2004, 10:21 PM   #32
OZDC's Avatar
Trader Rating: 16 (100%+)
Originally posted by Taylor-Racing
Good on ya' - I figured someone else must have thought of it before me.
meant to tell ya Gav, when I started running 1/8 approx 14 years ago this was the only type of gasket around. (2 o rings)
DC
OZDC is offline   Reply With Quote
Old 07-11-2004, 10:59 PM   #33
soc123_au's Avatar
R/C Tech Charter Subscriber
"The Fix" for the NTC3.
Its funny that all the good trick stuff listed here is all items under $10.00. Should be a message for any Newbs
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 07-11-2004, 11:46 PM   #34
screw driver I found on the side of the road had it for years the best fit I've ever seen
Old 07-12-2004, 02:05 AM   #35
rjl
rjl's Avatar
I had a "Pilot" brand hot pocket that was the best ever, went racing one day and haven't seen him since. I had had it for years and it never let me down, been through heaps since and they just don't last as long. Might have had something to do with the fact it was pink.
rjl is offline   Reply With Quote
Old 07-12-2004, 04:19 AM   #36
Taylor-Racing's Avatar
Originally posted by fraz
Gav and rjl,
On the o-rings. You say 2.6mm and 1.8mm "section". I take it that is the thickness of the o-ring, right? Now what ID are each of them and for which size motor?
Yes, by "section" I mean thickness.
The part numbers for the ones I buy are:
Viton 013
Viton 112
What I did was to take a crankcase and a header down to the local bearing supply and try a few on for size. These are for a Nova .12 engine and the ID isn't absolutely critical. I'm guessing the ID is probably 1 - 2mm smaller than the exhaust outlet, but they stretch over the wider section without a problem.The main issue is to ensure that the two smaller section ones are a snug fit when you install the header.
The larger one is essentially a second seal and something to take the compression forces exerted by the spring. It ends up fitting nicely into the radiused opening of the header, but it's too large to go inside the header when mounted.
Also, the newer Nova engines have a machined surface on the exhaust outlet but older ones are left as cast and exhibit a little flashing. I just file this flashing off and blend the surface in to avoid a possible leak.
Taylor-Racing is offline   Reply With Quote
Old 07-12-2004, 04:28 AM   #37
DC
Well there ya go. All these seasoned racers around and we're still using these crappy silicone items.
. . sounds like a market opening for DUDY, that inovative new Oz company.
Old 07-12-2004, 06:08 AM   #38
soc123_au's Avatar
Are they the same O rings you use in your Goat
Auswide Hobbies
JPM Racing
Old 07-12-2004, 10:02 AM   #39
Didn't work quite as well on the goat - seemed to restrict blood circulation somewhat, but it it sure didn't leak.
Old 07-19-2004, 08:45 PM   #40
rjl you were right about the wheel nuts by far the best I've seen when you think about it they are great value for money
Old 08-08-2004, 04:03 AM   #41
rjl
rjl's Avatar
Sullivan Ny-Rod inner makes the very best antenna tube.
Old 08-17-2004, 05:13 AM   #42
What are the best rubber and foam tyres you guys have found.
Old 09-13-2004, 09:26 PM   #43
Best servos that money can buy KO.
Old 09-21-2004, 09:08 PM   #44
HELLION's Avatar
Default some one stop me!!!
This Sirio outlaw 21 was In my Mugan MTX-2 and handled ok but I put it in The TC3 (in the pic) and it scaled almost perfect.Can't wait to try it out
HELLION is offline   Reply With Quote
Old 09-21-2004, 09:28 PM   #45
icon's Avatar
Send a message via AIM to icon
carbon fibre decal on the hood and wing of my car. lightened my car by 150g and i saw an increase of 10-15 mph. AMAZING!!!
seriously though, the best trick part IMO is a ball diff. pretty common nowadays but still so awesome. adjustable without messing with silicon fluids and much lighter than gear diffs.
icon is offline   Reply With Quote
Any V2 motor tip & trick? James khoo Electric On-Road 11 12-21-2006 10:22 PM
TRICK 05 XRAY!!!!! Factory Seal R/C Items: For Sale/Trade 3 11-14-2006 02:20 PM
TRICK 05Xray Factory Seal R/C Items: For Sale/Trade 2 11-13-2006 12:41 PM
trick mini-t cody branam R/C Items: For Sale/Trade 4 10-09-2006 10:05 AM
i need part number to this hitec part TomB Electric On-Road 2 05-23-2006 08:58 AM
