Old 07-07-2004, 07:38 AM   #16
Julius's Avatar
Default Re: RPM BUMPER
Originally posted by mop_iko
my RPM bumper....
its tough! really tough.
after a crash still alive. no bend or something!
mop
Didn't do too well in protecting the car though
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 07-07-2004, 08:10 AM   #17
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Default Re: Re: RPM BUMPER
actually the bumper PROTECTS IT VERY VERY well... the chasis didnt TWEAK AT ALL! the only parts are broken are:
the upper arm
the lower arm
the shock tower
i think the impact of the crashed was absorb by the bumper thus the chasis was not affected. and immidiately after the impact to the bumper the car swing transfering the impact to the arms and shock tower which are in CARBON GRAPHITE parts... and we all know carbon gaphite parts REALLY REALLY BRITTLE and SENSITIVE to impact and easily will be broken.
mop
mop_iko is offline   Reply With Quote
Old 07-07-2004, 09:35 AM   #18
R/C Tech Charter Subscriber
My best trick part was the 2 quarters I added to my 710 to make weight.
Thats my 2 cents LOL
www.twistertires.com
racinghobbies is offline   Reply With Quote
Old 07-07-2004, 09:39 AM   #19
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Hey Omar i thought you had a mugen? How do you like the 710?
Old 07-07-2004, 01:43 PM   #20
ROARprez's Avatar
My best trick part was the ROAR sticker I put on my car
ROARprez is offline   Reply With Quote
Old 07-07-2004, 04:58 PM   #21
rjl
rjl's Avatar
Gav's "O" ring gasket
rjl is offline   Reply With Quote
Old 07-07-2004, 05:13 PM   #22
PSI Racing's Avatar
Cool.
Thanks Taylor-Racing & rjl for getting that picture up for me.
I'll give that a try.
PSI Racing is offline   Reply With Quote
Old 07-07-2004, 06:46 PM   #23
intimidator's Avatar
jeesh mop,you might try a foam bumper along with that rpm,ive heard they work well?
intimidator is offline   Reply With Quote
Old 07-07-2004, 06:58 PM   #24
teammpp's Avatar
Originally posted by Taylor-Racing
The best trick part I found was to use "O" rings instead of those squishy silicone exhaust gaskets. They last for ages.
. . must get some more of those.
"Marui Big Bear"
Yep. Brilliant idea. Thats all we ever used when racing 1:8th. Definately keep the seal better and rarely wear out or break.
With the .12's I have been replacing the rubber gaskets maybe twice each meeting from the splitting etc... I recently switched to the Team Titan gaskets and havent had to change one in 2 full days of racing.
teammpp is offline   Reply With Quote
Old 07-07-2004, 10:30 PM   #25
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default gaskets
I`ve been useing the same GQ Gasket for 4 race meets so far and no leaks, hell you can barely get the header on or off very easy.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 07-07-2004, 11:15 PM   #26
wild gopher's Avatar
Trader Rating: 39 (100%+)
where do i find team titan gaskets?
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 07-08-2004, 04:58 AM   #27
Taylor-Racing's Avatar
Good on ya' - I figured someone else must have thought of it before me.
Your right about the normal gaskets splitting.
It seems to me that the coloured or translucent ones are all pretty weak. The best we found were the black Serpent ones. They have sort of a matt finish and are a bit tougher than all the coloured ones - still nowhere near as tough as the "O" rings, though.
I find if the header isn't aligned exactly right, the gasket will be split in no time - puts too much pressure in one spot. A "springy" mounting wire makes matters worse.
Haven't tried the Team Titan or GQ ones.
BTW, many thanks to rjl and Microsoft.
Taylor-Racing is offline   Reply With Quote
Old 07-08-2004, 05:31 AM   #28
finchy's Avatar
When I bought a trick bit for my V1rr Evo, it was called Mugen Seike MTX-3. Seroiusly I get this silicon tube stuff for the exhaust joiner from Morris Sugerical. It's pretty durable stuff. I like the old exhaust type setup, not in-line.
Inf1nity IF1
OS Speed
KO PRO PO
Runnertime
Hudy
finchy is offline   Reply With Quote
Old 07-08-2004, 05:21 PM   #29
teammpp's Avatar
The only reason we caught on to the o-ring was that the older JP Rex .21 engines we ran came with them as standard. The Team Titan ones come in red and blue but they are similar in texture to the Serpent ones.
Howard at Titan Racing told me that RD Logics are the importers for the US. Havent seen much about them from their site etc so not sure what the story is.
Old 07-09-2004, 12:23 PM   #30
fraz's Avatar
Send a message via AIM to fraz
Gav and rjl,
On the o-rings. You say 2.6mm and 1.8mm "section". I take it that is the thickness of the o-ring, right? Now what ID are each of them and for which size motor?
fraz is offline   Reply With Quote
Any V2 motor tip & trick? James khoo Electric On-Road 11 12-21-2006 10:22 PM
TRICK 05 XRAY!!!!! Factory Seal R/C Items: For Sale/Trade 3 11-14-2006 02:20 PM
TRICK 05Xray Factory Seal R/C Items: For Sale/Trade 2 11-13-2006 12:41 PM
trick mini-t cody branam R/C Items: For Sale/Trade 4 10-09-2006 10:05 AM
i need part number to this hitec part TomB Electric On-Road 2 05-23-2006 08:58 AM
