Old 10-07-2010, 10:52 AM   #1
Trader Rating: 40 (100%+)
Default Capricorn 1/8 Competition racing car
Cad photos on redrc.net
A quote from Redrc.
A super low centre of gravity aids the handling, while ease of access to all the parts and an intuitive and fast set up system make the car enjoyable to work on. They expect to perform further testing and development in this final part of the year and aim to have the car ready for the start of the 2011 season.
Capricorn 1/8 Competition racing car-capricorn8th-3.jpg   Capricorn 1/8 Competition racing car-capricorn8th-1.jpg   Capricorn 1/8 Competition racing car-capricorn8th-2.jpg
Got the grip is offline   Reply With Quote
Old 10-08-2010, 01:07 AM   #2
Wanabrc's Avatar
Trader Rating: 70 (100%+)
Super low center of gravity? How much lower can it get then the current crop of cars?
Wanabrc is offline   Reply With Quote
Old 10-08-2010, 06:04 PM   #3
DS Motorsport's Avatar
There is always room for improvement.
Just take a look at how low the 2-speed axle is and how small the gearbox is.
Also the bulkheads are small and low.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 10-09-2010, 08:44 AM   #4
JetMD's Avatar
Maybe it's just me but it seems that putting the first gear spur the same height as the bottom of the chassis is asking for trouble. I'm sure most people will find scratches on the bottom of their chassis so you'll run the risk of the spur gear touching the ground. After some testing, i'm guessing that will change.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 10-12-2010, 02:53 PM   #5
Many modern cars have the first gear at the same height as the bottom of the chassis, Xray NT1 for example, and haven't heard of anyone having issues chipping teeth or damaging spurs.
The reason why the entire 2-speed axle assembly is lower is because Capricorn changed the spur/pinion ratio which allows them to use much smaller diameter gears.
P1-RC.com
Old 10-12-2010, 02:59 PM   #6
wingracer's Avatar
Trader Rating: 24 (100%+)
That means the internal ratio would have to be changed.
So you either make the rear pulley bigger, which raises the rear axle, negating much of the advantage of lowering the two speed shaft, or you make the drive pulley smaller, reducing belt wrap which means easier to strip a belt.
Not saying these will be problems, I have no idea as no one has even seen the car much less run it, just talking about theory.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-12-2010, 03:31 PM   #7
KMW
KMW's Avatar
The NT1 and LAB-C01 have the same internal drive ratio, but the LAB uses smaller (as in less teeth) spur gears to accommodate a 2mm drop in the 2-speed assembly height. Your post is over thinking the solution to this...
KMW is offline   Reply With Quote
Old 10-12-2010, 03:35 PM   #8
I think I misstated.
An Xray NT1 uses an 59 spur with a 17 pinion.
A Capricorn Lab C01 uses a 52 spur and a 15 pinion with the same internal ratio.
This gives the same final drive ratio but with different amount of teeth of the spur and pinion.
And a smaller spurgear, so the possibility to lower the 2-speed axle.
With the modern composites used these small gears aren't an issue anymore in terms of wear and reliability.
P1-RC.com
Old 10-12-2010, 05:20 PM   #9
wingracer's Avatar
Yeah that's doable but such small pinions (we go down to 15 with conventional clutches already) may require a smaller clutch bearing. I am not a fan of 5x9 in 1/8th but hey, I've done it before (Picco Integra) so might work.
Team Shepherd USA
Old 10-12-2010, 05:25 PM   #10
wingracer's Avatar
Plus, I just did an admittedly rough count through a blow-up of the cad drawing and came up with 50 so unless the pitch is smaller, it's the same size gear as everyone else uses.
Team Shepherd USA
Old 10-12-2010, 07:14 PM   #11
GMartinez's Avatar
Trader Rating: 85 (100%+)
Is it me or does it look similiar to the serpent 966 but I would imagine it will have some really good lt weight parts
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 10-21-2010, 01:02 AM   #12
Wanabrc's Avatar
Anymore updates?
