Old 10-03-2010, 11:32 AM   #1
Default need help my novarossi 35 plus 21 engine is slightly rusty
hi people i have a novarossi 35 plus 21 engine and its slightly rusty.whats the best stuff to get rid of rust underneath piston and in engine.the engine hast seen any after run oil since being running so this is the problem for the rust.ive now bought new rear bearing and novarossi after run oil.if anyone knows anything i can use to resovle the rust i would apresiate it.
cheers people
kyoshoevolvam3 is offline   Reply With Quote
Old 10-03-2010, 11:42 AM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
The piston is aluminum so it will not rust. You're probably just seeing carbon and burnt up castor deposits. Nothing to worry about.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-03-2010, 11:53 AM   #3
thankyou for ur comment ok but i have however noticed theres a slight film over the conrod as if it were feul sill on there like oil or something is that anything to worry about
cheers
Old 10-03-2010, 12:33 PM   #4
Geezatec's Avatar
cheers
Film you see is caster from fuel. It is natural. no problems. Wanting to remove film, use paint thinner or at auto parts store, purchase a can of Berryman's carb cleaner. It'll remove the film. May use a toothbrush to remove stubborn, burnt on film.
Geezatec is offline   Reply With Quote
Old 10-03-2010, 12:36 PM   #5
wingracer's Avatar
What he said. It's just the oil (and dye if the fuel has any in it) dried up on the surface.
Team Shepherd USA
Old 10-03-2010, 12:57 PM   #6
Roelof's Avatar
Send a message via ICQ to Roelof
Rust can only be seen on the bearings and crankshaft. If there is rust just take the engine apart and high likely you can wipe it off with a towel.
Heavy rust can be wiped off with a Scotch Brite pad but do not touch the crankpin.
Brown spots on other parts is for sure no rust.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 10-04-2010, 01:01 AM   #7
Wanabrc's Avatar
Trader Rating: 70 (100%+)
Just use some fuel on a lint free rag to wipe it off.
Wanabrc is offline   Reply With Quote
England Park Raceway, Brendale. acs Australian Racing 8473 12-10-2017 04:18 PM
