Old 09-25-2010, 03:34 AM   #1
Default whats the best thing to clean engine bearings
Hi people I have a novarossi 35 plus 21 engine I haven't used it many times but I've noticed the rear engine bearing looks as if its rusty and I don't know why does anyone have any idea how I can resove these problems or what products I can use to clean them.
cheers
kyoshoevolvam3 is offline   Reply With Quote
Old 09-25-2010, 04:48 AM   #2
gfilos's Avatar
cheers
usually, some rust appears on the surface of inner and outer rings of the bearing as you look it from the backplate. If the bearing works smoothly (stick your finger in and try to rotate it, it should feel very smooth and no play) no need to clean the surface. Take the crankcase off, spray the bearing with some brake-cleaner let it dry, and re-oil it with some after-run oil. Do not spray the crankshaft with brake-cleaner if it has red putty inside.
Always use after-run oil to avoid rust inside the engine. Apply a few drops from the plug hole and a couple of more from the carburator hole. Use the engine starter for 2-3sec. If you are not going to use the engine for a long time, take the engine off the car, remove the glow plug, and put it in an air trapping bag after you have sprayed the bag with some wd-40.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 09-25-2010, 05:29 AM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
I have seen this before and could wipe it off with an alcohol-napkin.
The quality of an answer comes with the quality of the question.
Roelof is online now   Reply With Quote
Old 09-26-2010, 12:51 AM   #4
Thanks for comments people so after I clean rear bearing what should I put to lube them. Afer run oil ?
Cheers
Old 09-26-2010, 01:49 AM   #5
gfilos's Avatar
Cheers
yeah after run oil will work, you just need to lube it so when engine starts bearing is not dry. you can also use some bearing oil.
1/8th scale Motonica smac Nitro On-Road 1830 01-16-2012 10:34 PM
A few pics of my Revo killer offr0aden Monster Trucks 103 10-03-2009 08:54 PM
