Old 04-27-2011, 01:46 PM   #451
Drew Ellis's Avatar
Default Clearing things up.
The springs that we ran were the red 35lb. The part number for (4) springs is #308388...The part number for (2) springs is #338288..These springs are just for the rear.
The spring has been around for awhile, so many of you might already have them from the NT1 and the electric cars.
It is the light red (35lb). The dark red is the (38lb).
Thanks Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 04-27-2011, 06:31 PM   #452
Default body
Thanks Drew
What up Drew? I'm good and can't wait to get this car on the track!!
Gotta order springs also waiting for you to get the set up posted so I can put it on my car. I will hit you up soon also have some other quesstions for ya
TTYL
Charlie Williams
RC America/Xray,Hudy
Charlie Williams is offline   Reply With Quote
Old 04-27-2011, 06:32 PM   #453
Default oopa
TTYL
questions
Charlie Williams
Old 04-27-2011, 09:57 PM   #454
Drew Ellis's Avatar
TTYL
Right on, just waiting for Xray to get the setup sheets online. As soon as that happens we will have some set ups on there. I will see what I can come up with on here for you guys for the time being. Have to go to Cali tomorrow, but get back on Monday.
Thanks Drew
Old 04-27-2011, 10:18 PM   #455
Alex C's Avatar
Trader Rating: 50 (100%+)
OK guys below is a list of info for the RX8.
The bodies the team liked the most was the R15, there were a few that liked the 909. So I think if you have both you will be fine at any track.
The clutch, you will need to seat the clutch before running. Set the clutch lose about flush with the nut. Run a tank or two on the starter box revving the engine up to engage the pad. This will let the pad break in and perform better. You are looking for a light blackish mark on the pad.
The springs, right now the mugen white is the closest to what the team ran in the front. Xray should be shipping the new springs soon. The Xray rear 35lb and 38lb spring will work fine.
The shock oil setup. I think a good starting point is 2 hole fixed all the way around. Ralph ended up with 3 hole fixed 700 in the front and 2 hole fixed 550 in the rear. That is what he liked best at the WC.
Tires, most of the team ran 32 fronts and 35 rears. they ran between a 6mm to 7mm split.
The bodies were mounted 23mm forward. The measurement was taken from the middle of the bumper with the body mount forward.
The flex on the radio tray seemed to make more steering then having it with no flex. I am sure that will differ with each racer. Ralph, Mike and Paul ran the flex.
Hope this helps some as we will be having more info soon. Please post any feedback here.
Thanks Drew
Thanks Drew for the update, can't wait to receive my RX8's !!!!
Best Regards!!!!
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 04-28-2011, 02:26 AM   #456
Thanks Drew
Excellent information , Thank you and please keep it coming, The more info is shared the better the RX8 experience will be and therefore encouraging more people to purchase the car.
Serpent 966TE , GRP .21, Picco 2033 Tuned pipe, Futaba 3GR 2.4ghz, SRC Zytec v2 shell
eigthracer is offline   Reply With Quote
Old 04-28-2011, 07:42 AM   #457
MAD916's Avatar
Great Info Drew Thanks: Looking forward to joining the team and waiting for the RX8 and some good weather to show up here in the NW.... looks like a 70 degree sunny weekend coming up, so we will be out scrubung the moss off with some 32 shore foam sand paper
Keep the info coming....
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 04-29-2011, 10:46 AM   #458
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
the car build like a dream, about to put electronics and motor into it, i will have it out next week, mid week for some testing OH YEAAAA.i have the mugen whites, and that 38lb spring for rear as well...guessing the supplied oil is the way to go, with 2-hole fixed pistons.....this car has alot "inside" u cannot tell, but when u build u can see the adjustments are endless/ i imagine setups will be coming for a LONG time, wich is sweet, means our car will get better and better, the xray composite plastic is in a league of its own!!!!! anyone break anything yet btw?
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 05-02-2011, 09:08 AM   #459
Chewdogg's Avatar
Default Shock Rebound?
Guys,
When (track conditions) should I use the different shock rebound settings? I see lots of setups at 50% but I was wondering about 0 and 100%.
thanks
MAX POWER AMERICA
Chewdogg is offline   Reply With Quote
Old 05-02-2011, 10:05 AM   #460
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Drew!
I am returning to Xray. I have a NT1 WC due to arrive today. Should I build it per the kit instructions or is there any recent tweaks I should consider?
Brian
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 05-02-2011, 10:33 AM   #461
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
car is outstanding
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 05-03-2011, 10:28 AM   #462
Drew Ellis's Avatar
Originally Posted by Slapmaster6000 View Post
Drew!
Brian
Brian,
Great to hear. I would start with Ralph's setup. Just go to www.teamxray.com and go to setup then setup search and type Ralph Burch in, all his setups will be there. The newest one is what we are running.
Also guys sorry I have not been on here just got back from are first Xray Challenge.
Thanks Drew
Old 05-04-2011, 06:49 AM   #463
drew ill post here, as it bothers you to check out the rx8 thread for some reason.....Lipo SRC 1600 rx packs that u suggested in the rx8 thread, this is the pack that will let me lower the tank 3mm as suggested in advertisment for car? RX8?
Old 05-04-2011, 07:03 AM   #464
Drew Ellis's Avatar
Yes this is the pack that will let you lower the tank. NT1 and RX8.
And you can post where ever you want. But don't get upset if no one from RCAmerica does not jump on your question in the other thread. As this is the RCAmerica thread. If you would rather get your info from someone you don't know then post there, if you want info you can trust then post here. Its pretty simple, have a question for RCAmerica/Xray USA post here.
Thanks Drew
Old 05-04-2011, 07:30 AM   #465
Thanks Drew
well stated...ok i want the pack, can u shoot link where to buy it..i didn't see the 1600...i saw the src area, but when i went into x-shop i couldn't navigate anywhere? thanx....
1/12 forum ovalnator Electric On-Road 46181 Yesterday 02:42 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Ask Mike Blackstock Trinity ,Rcamerica, Team Xray Edition.. Mike Blackstock Electric On-Road 225 12-30-2006 06:57 AM
RCAmerica/ Xray / Hudy Mark G Electric On-Road 10 03-15-2006 09:17 PM
RCAMERICA Live Race Coverage @ The Dirt Nitro Challange David Joor Electric Off-Road 40 03-03-2005 12:33 AM
