Old 09-17-2010, 10:53 AM   #1
wmay11's Avatar
Default 07010/1 Conrod
Is the NR 07010/1 conrod compatible with the R7, 07009??? What motor is it for?
Thank you
Warren
RX8 - Savox - Reds Racing - Ko - Contact - Enneti
wmay11 is offline   Reply With Quote
Old 09-17-2010, 11:03 AM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
Thank you
Warren
No it is not. C rods have a smaller crank pin for the "Colari" edition motors. If your motor has an R rod, you can use any R rod.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-17-2010, 11:49 AM   #3
wmay11's Avatar
Will it fit the 359?
Old 09-17-2010, 12:05 PM   #4
wingracer's Avatar
No, even smaller crank pin. Those need the P rods.
You basically have three main Nova .21 rod types.
R series. Big crank pin. Most Nova motors, 35+21, Flash, Kangaroo, all MaxPower, etc.
C Series. Smaller crank pin for Collari motors, 35+21 Collari, Cordoba, etc.
P series. Even smaller crank pin for 359.
Then there is another rod for the short stroke offroad motors (pre-2000 BF)
Team Shepherd USA
Old 09-17-2010, 12:29 PM   #5
wmay11's Avatar
Thanks Sean, makes things clear, and I think the new Collaris run the R rod?
Take care
Old 09-17-2010, 12:43 PM   #6
wingracer's Avatar
yeah the long pilot shaft Collari (Novarossi 35 PLUS 21 LC/WC09 Limited Edition) takes an R.
Team Shepherd USA
Old 09-17-2010, 01:19 PM   #7
wmay11's Avatar
I suppose all you need to do is change the cranks on the motors to run the rod you want??
Old 09-17-2010, 01:25 PM   #8
wingracer's Avatar
Yeah you could. As long as you have a 14.5mm crank motor. I could be wrong but I think all the 14mm crank motors use R rods.
Team Shepherd USA
Old 09-17-2010, 01:39 PM   #9
captian's Avatar
That sounds right
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 09-17-2010, 01:49 PM   #10
captian's Avatar
t
I need one of those cranks know where I can get one
Old 09-17-2010, 02:02 PM   #11
wmay11's Avatar
Well that is good news, covert the Cordobas and the 359 cranks and you ready for R7!!!!
Sean you da man!!
Old 09-17-2010, 02:09 PM   #12
wingracer's Avatar
Sean you da man!!
I love Frankenstein motors.
My current club race motor is a bone stock Max 721 except for the crank which came out of the BADDEST old R1 I have ever seen. Runs great.
My Nats motor was a 35+21 with a great mod crank from an old 21+3 in it.
Also had an old RB C5 with a bunch of Kangaroo guts in it that was great until she finally blew slam up.
Team Shepherd USA
Old 09-17-2010, 02:17 PM   #13
wmay11's Avatar
Bring on the Frankenstein, I think I am going to stuff around with these ideas, you have opened up a can of worms bro
Old 09-17-2010, 02:21 PM   #14
nitrodude's Avatar
359s had crankpin problems. On mine the crank pin broke off the crank. We just put a 35+ crank in it and it runs great. It changes the power curve a bit though.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 09-17-2010, 02:33 PM   #15
wmay11's Avatar
Probably more torque? Is it still up there with the rest or does feel a bit sluggish?
