Old 07-23-2004, 08:22 PM   #121
Originally posted by dino.tw
Cool spill plate idea Sir Dino
Did you rub the mid-belt with that plate on purpose?
GoldFinger is offline   Reply With Quote
Old 07-23-2004, 09:21 PM   #122
Nitro Tech
dino.tw's Avatar
No. The mid-belt was rubbed by my other pipe and belt tensioner bearings. There are 5mm distance between that plate and belt. That plate was made by body residue.
dino.tw is offline   Reply With Quote
Old 07-23-2004, 09:42 PM   #123
So the plate should be above the belt ?
Old 07-23-2004, 10:28 PM   #124
Nitro Tech
dino.tw's Avatar
Between the graphite radio tray and receiver mount.
Old 07-23-2004, 11:19 PM   #125
Suspended
Default NEW RIMS
HAVE U GUYS SEEN THE SALVEN'S NEW RIMS ON THAT 950R?
SERPENTFREAK69 is offline   Reply With Quote
Old 07-23-2004, 11:24 PM   #126
Ok. Thank you.
Is there any other tips and tricks Sir ?
Old 07-24-2004, 02:58 AM   #127
PSI Racing's Avatar
Check this out.
http://www.serpent-usa.com/product-page-ser100005.html
PSI Racing is offline   Reply With Quote
Old 07-24-2004, 02:59 AM   #128
PSI Racing's Avatar
And this too.
http://www.serpent-usa.com/product-page-ser100008.html
Old 07-28-2004, 08:58 PM   #129
Default Re: Re: Re: Re: Re: Re: Track Width
Originally posted by MrChan
I'm using JP with Mugen Superhard Clutch Spring(1.9 mm diameter) .
~ 1 mm . I think but If i have to tighten too much to get bottom end, I will change to use harder spring such as Mugen SuperHard, SMP Clutch Spring..
But If you use the clutch shoe with round spring in the center, I think u might not need to tighten so much ...
Thank you Mr.Chan and Dino too.
With that clutch combo, its enough to put me 5th on grid and finish 3rd.
To be honest, it is the car not the driver. Everybody had some fine tuning problem since the track was resurfaced.
But my 950R has not rebuilded from the last race and its getting even better funny but its true.
1 more thing Mr. Chan, what is the handling effect with putting the front arm into higher position?
My aim is to reducing the handling change vs tire wear.
On last race, start with 7.5mm split, ended up with 6.4 split.
After start, my car is only 80% dialed and getting faster and faster toward the end.
The problem is, in early lap, my laptime is down near .6 - .7 sec compare to all of the fast guys. On 80th lap marks i was down 5-6 lap already. After that, my car is fastest on the track and I can chase them and ended with 3 lap down from no1 and 1 lap from no2.
That time, I feel that my car is getting faster and the others is getting slower. After the race i was asking the reace director to print the lap to lap for me.
I was wrong. Yes im getting faster and faster but the other is damn consistant!!
Here is the figure, the fastest guy is lapping on 15.2~16.0
I made 16.5~15.9 and after lap 85-160 I can lap 16.0~15.5.
Is it me or there something we can improve on the setup?
Sorry for long reading.
Thank you
Old 07-29-2004, 09:26 AM   #130
MrChan's Avatar
Send a message via ICQ to MrChan
Default Re: Re: Re: Re: Re: Re: Re: Track Width
It means you do the lower roll center .. I think you get more on throttle steering .
MrChan is offline   Reply With Quote
Old 07-29-2004, 06:36 PM   #131
Bandicoot's Avatar
Hey guys, anybody using the M8 radio succesfully with a fail safe? I heard from airtronics that the dynamite 2550 does not work with it and the 2551 does, dynamite also makes a 2553 micro unit that I know nothing about. Is anybody using the Venom and M8 with success
Bandicoot is offline   Reply With Quote
Old 07-29-2004, 06:51 PM   #132
tomkelley's Avatar
I have 3pk so fail safe is built in. If a frequency conflicts I have it set to go full break. Does yours have a feature to fail safe when there's a frequency conflict, or just too low battery or transmitter off? I generally don't like external fail safe's but just make sure you have a good rubber band or throttle return spring and you should be fine. Sometimes full break and full right steer could be hazardous at full speed.
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
Old 07-29-2004, 07:45 PM   #133
Default Re: Re: Re: Re: Re: Re: Re: Re: Track Width
Ok, I will try on next outing.
I try wider FR trackwidth, 255mm like you suggested.
Braking is awesome! but the car change direction bit slower. Not in chicane, its like when I avoiding something and try to get back on the line it took a lot of time.
Old 07-29-2004, 08:46 PM   #134
MrChan's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Track Width
I think u can play with the rollbar.. Harder Rollbar make the car more responsive.
Yeah, Some of my friend also said my car is dead and stable ... ha ha ..Some of my friend said he dont like the car is not so responsive for him ..but too me I like that way ..because I'm not a smooth driver ...ha ha
Old 07-29-2004, 09:04 PM   #135
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Track Width
I guess i was too smooth.. ha ha ha..
WTB serpent 960 or 950R rcmad2700 R/C Items: Wanted to Buy 0 05-21-2008 10:46 PM
looking for serpent 950r /960 mrhemi R/C Items: Wanted to Buy 4 01-02-2007 09:10 AM
Serpent 950R and etc. ogreasurada R/C Items: For Sale/Trade 35 03-03-2006 11:30 PM
Serpent 950r Afrofly Oval, Larger Scales and More 1 03-02-2005 05:02 PM
Serpent 950R Neil Rabara Oval, Larger Scales and More 12 03-14-2004 06:43 PM
