Old 06-23-2004, 10:10 PM   #16
Suspended
Default Re: My 950R
Originally posted by MrChan
ARE THOSE QUICK RELEASE ON YOUR WHEELS?WHAT ARE THOSE?
SERPENTFREAK69 is offline   Reply With Quote
Old 06-23-2004, 11:21 PM   #17
Arno's Avatar
Default Re: i have a MS EVO5
Originally posted by SERPENTFREAK69
IN MY 950 AND I HAVE NEVER HAD ANY PROBLEMS WITH IT,ITS A GREAT MOTOR.I AM THINKING OF UP GRADING MY 950 TO A 950R...WHAT DO U GUYS THINK I SHOULD DO?
I think its a good idea to upgrade but I think you should just get the conversion kit for the front and leave the throttle servo the way it is. Because as I said before when the throttle servo is layed down it sticks out and if you get hit on that side the ears of the servo case break off.
Arno is offline   Reply With Quote
Old 06-23-2004, 11:26 PM   #18
Arno's Avatar
Default Re: My 950R
NICE!!!!
I have that NOVAMAX also I am waiting to get it back from Italy I sent it back to Masimo Fantini to get repaired because it was defected from the day that I got it. How do you like that engine?
Old 06-23-2004, 11:38 PM   #19
MrChan's Avatar
Send a message via ICQ to MrChan
Default Re: Re: My 950R
Originally posted by superserpent
NICE!!!!
The engine is very strong ...and very fast...
I feel the engine is very smooth power band.
I got JP FX-R02 also but I could done the better lap time with MAX .. JP is very powerful too and I think it 's a bit better than MAX at Low and MID ( Personal 's think) I might because I 'm not use to power band of JP ..the way of tuning to match my driving style.
But too bad I got a bad luck with the MAX engine ..I broke 2 times already ...2 times were all my mistakes. Just like I want to change the conrod in next run but It broke before ..
I think the high rev engine will have to change conrod on time.
MrChan is offline   Reply With Quote
Old 06-24-2004, 01:50 PM   #20
revzalot's Avatar
Default Help cutting holes!
I need help cutting the appropriate holes for the engine, roll bar, body clamps. How'd you guys do it? I don't want to mess up. Someone have a template?
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 06-24-2004, 05:29 PM   #21
tomkelley's Avatar
Default Re: Help cutting holes!
I actually used an old body as a template. I just dropped it right on top and made markings from strait down. Unfortunately my front post was off, and I had to widen the hole down.
Another way to think about it is to line up the body with the front bumper plate after having cut away the engine, roll bar and fuel tank opening. then line up your body mounts. I think if you get the serpent lola vds body it has proper indications where the holes should be.
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
Old 06-24-2004, 05:34 PM   #22
Sow&Steady's Avatar
I know its too late for this one since you've painted it but usually its best to use a permanent marker and mark the holes on the outside of the body BEFORE you spray paint.
Never mind, I'm sure we've all done the same mistake at one point or another.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-24-2004, 06:26 PM   #23
revzalot's Avatar
I agree. Next time I should completely finish the car before starting the body.
Old 06-25-2004, 09:59 AM   #24
serpentsixty9's Avatar
Send a message via AIM to serpentsixty9 Send a message via Yahoo to serpentsixty9
i use a hpi lola on my 950r, and when it came time to make the holes for the airfilter, engine, and tank, hpi's lines already in the lexan matched up perfectly! but the body post holes were a little off. i know its an old body lol, but hey, u work with what u've got right?!
serpentsixty9 is offline   Reply With Quote
Old 06-25-2004, 10:08 AM   #25
tomkelley's Avatar
I heard the hpi lola was a bit lower than the serpent. Does anyone stock the Delta Lola? Or we supposed to call delta directly?
www.drccc.org
Old 06-25-2004, 10:26 AM   #26
revzalot's Avatar
Default Delta Lola
Give Lee a try:
http://www.gasrccar.com/
Old 06-27-2004, 07:21 PM   #27
Arno's Avatar
Thumbs up
I just started using the new lola body from protoform and I must say it is the best body I have ever used it is really stiff, and it handeles great. I guarantee all you guys will love it too.
Old 06-27-2004, 07:31 PM   #28
MrChan's Avatar
I just started using the new lola body from protoform and I must say it is the best body I have ever used it is really stiff, and it handeles great. I guarantee all you guys will love.
Yep.. I have just used it yesterday race.. The handling is perfect ... a lot better than Serpent EVO2 ......the same setting but Photoform will give you more on power steering and very stable. this bodyshell I could brake very very hard ......as the same braking amount, I couldn't brake with Serpent EVO2 shell
Old 06-30-2004, 11:33 AM   #29
Arno's Avatar
The best way to do this is the first time take your engine and rollbar off put the body on make the holes for the body posts first then do the engine and the roll bar. Then when the body is totalled and you are going to throw it away, cut the top part of the body off and keep it as a template for your next body. Hope this helps.
Old 06-30-2004, 04:41 PM   #30
Suspended
Default nice body
is that a new body on your serpent 950r?
WTB serpent 960 or 950R rcmad2700 R/C Items: Wanted to Buy 0 05-21-2008 10:46 PM
looking for serpent 950r /960 mrhemi R/C Items: Wanted to Buy 4 01-02-2007 09:10 AM
Serpent 950R and etc. ogreasurada R/C Items: For Sale/Trade 35 03-03-2006 11:30 PM
Serpent 950r Afrofly Oval, Larger Scales and More 1 03-02-2005 05:02 PM
Serpent 950R Neil Rabara Oval, Larger Scales and More 12 03-14-2004 06:43 PM
