Serpent 950R
#151
Re: Re: About the 32-37
Originally posted by GoldFinger
Check this :
http://www.mytsn.com/setups/setup.asp?sid=2659
very interesting setup.
Check this :
T T "
Front Left 32 , Front Right 35
Reat Left 32, Rear Right 37 !!
The track must be anti-counter clockwise . Anyway, I still very confuse ...How to run like that !!
If left 32 and right 35 ...It 's not so special ...But this one , Front and rear right is diff too. Make me think to hard how to run ?
#152
Re: Re: Re: About the 32-37
Originally posted by MrChan
T T "
T T "
Maybe they are having a bad batch from ellegy or forgot to bring durometer.
But when reading the report, there is Picco, Salven, KHM too so the question is : Is there no other way?
I dunno about the layout, when comparing with Julius setup on the previous month (using 710) he was using 40R all around
#153
Here's the track
Surfing through mytsn.com and researcing more about Ilia's setup, I found a pic of the track he used the setup on. I was right about a NASCAR type track with a long left sweeper in the back. Wow! I wonder what tops speeds can be reached on that sweeper?
Link of track
Link of track
#156
Most people I know put one degree in the rears and none in the front.
#159
I still measure them on the outside but the middle would probably be a better idea.
#160
Hi to all,
Does anyone know how to remove the dog bone pins from the hudy steel dog bones? Serpent has discontinued the special pin removing tool but continue to supply the replacement pins..... And to replace the dog bones(four pieces) is not cheap and also pretty wasteful....
Thanks.
Thanks.
#162
Originally posted by Bandicoot
I would press the old pin out until flush with the ball using a bench vise and an old socket for a support and then when the pin is flush use the new pin to push the old one all the way out and in the same time you also have the new pin pushed in
