Old 09-11-2010, 09:22 AM   #1
Default Kyosho Fazer steering needs help!
I've just got two of these and it's a fast car for the car parks (I don't race), I like it but I have a problem.
Both of them veer off to one side even with the trim set to line the wheels straight. It's a pain in the backside especially at speed.
Are there any hop ups I can get to sort this or did anyone with a Fazer solve this issue? I was thinking about a better servo but I don't know if the problem is rubbish linkages? Even my old Tamiya TGS slooooooooooow nitro stayed straighter than this!
kabulu is offline   Reply With Quote
Old 09-11-2010, 10:26 AM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
Never had a Fazer but there are many things that can cause this, few of which have anything to do with the steering.
First, check to make sure all four tires have drive. A broken dogbone or stripped wheel hex or something like that will cause all sorts of problems.
I suspect the problem is a lack of traction with a shaft drive. Shaft drive cars suffer from torque steer, especially if the tires break loose under power. I doubt the stock tires have a lot of grip.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-11-2010, 11:30 AM   #3
Thanks. I notice the fazers steering servo is pushed/pulled from only one side which might be a problem but i'll check the shafts. Thanks
Old 05-20-2011, 08:27 AM   #4
I got this problem too mate, did you end up fixing yours or not as I want to do mine too ?
johnii is offline   Reply With Quote
