Old 01-15-2011, 09:01 PM   #46
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by DJ_Shakespear View Post
OK guys, Ive painted up and trimmed the P37 body, but I think Ive run into a problem.
In the AARCMCC rules it says that the maximum height from the rear bumper to the ground including a 10mm spacer under the chassis is 50mm, but since mounting it onto my car, its almost 60mm - i followed the trim lines and I could only find 1 trim line, not 2 like some bodies have.
Is this normal, or did I not see a lower trim line??
I had a similar problem (although not 10mm) with the P56 but not with the P37
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 01-15-2011, 11:06 PM   #47
So are there 2 trim lines on the rear bumper area?? I just don't remember seeing any more than 1!
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 01-18-2011, 09:31 AM   #48
Dj_Shakespear;
Must confess, I'm a bit confused by the body trim line problem you're having. The molded rear trim line on the P37 body was made to conform to the EFRA GBS (Global Body Spec) rule: Max 50mm measured with a 10mm spacer under the chassis plate level.
I have a fully trimmed Protoform P37 sitting on the table right in front of me. It's trimmed on the body line all the way around - so it's not raked in any way.
With a 10mm spacer under it the rear trim line is 48mm off the table. That's 2mm under the maximum allowed.
So - I can't figure out what you're talking about.
Incidentally, the ROAR rule for the rear trim line is being changed to conform to the EFRA wording.
Dale - Protoform
daleepp is offline   Reply With Quote
Old 01-18-2011, 11:20 AM   #49
Geberit's Avatar
I had this problem with one of the first P-56! I trimmed it without paying any attention down the marked line so it was my own fault I got it wring.
Now I'm just more careful when I trim the body ...
The Proto body's are MEGA
Geberit is offline   Reply With Quote
Old 01-22-2011, 10:07 PM   #50
quietstorm76's Avatar
Has anyone ran the P-37 and Chevy Cruzer back to back? How do they compare?
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 01-23-2011, 04:26 PM   #51
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default comparison
not yet but will do it next week at the forgass race
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 01-23-2011, 05:00 PM   #52
Originally Posted by daleepp View Post
Dj_Shakespear;
Dale - Protoform
So is there only a single trim line at the rear that makes it less than 50mm high? I just don't remember seeing a second line, which I was happy about so I left it like that. Maybe its just the way I had it mounted on my car - Kyosho RRR but I also have these circular things that go on the posts so you can raise the body to a precise height instead of using body pins underneath, maybe that caused it to be a little higher.
Other than that, it ran quite fantastically - engine was running hotter than I wanted because I didn't cut the front side windows out, plus my tank lost its seal after a pit stop so I ended up with a 200 C degrees motor!! Luckily nothing blew - except the plug - and after that it was perfect!
Old 01-24-2011, 06:47 AM   #53
Please let me know. I'm just about ready for Winter Nats, just need to make final body choice.
Primary Weapon: ?
Secondary Weapon: ?
Old 01-24-2011, 02:18 PM   #54
Gael L's Avatar
When I tested them back to back I found that the Chevy was a little more aggressive corner entry where as the P-37 seemed a little more all around stable. Lap times were nearly identical so it will be more of a matter of feel on each track. In the fast sections like a crosstown at my local track I could be a bit more aggressive with the P-37. P-37 felt a little closer to the Blitz RS4 with a little more steering. The Chevy makes the car feel like it has more roll in the corners. Either one would be a great choice for the Fort.
Hope this Helps
Gael
Gael L is offline   Reply With Quote
Old 01-24-2011, 03:27 PM   #55
Default body choice
I would bring both if you can
Old 02-02-2011, 07:29 AM   #56
MackanG's Avatar
@Dale Epp
Have you started to produce this body and P56 with EFRA number in the windshield? Or are they not yet homologated?
/Mackan
MackanG is offline   Reply With Quote
Old 02-02-2011, 11:00 PM   #57
Suspended
Trader Rating: 19 (95%+)
looks like it would work well.. I guess we will see.
jiks0983 is offline   Reply With Quote
Old 02-04-2011, 04:03 PM   #58
What's the deal with body stiffeners, is it better to glue or bolt them?
Thanks.
JIM1 is offline   Reply With Quote
Old 02-04-2011, 07:59 PM   #59
Thanks.
I would think bolting them would be heavier but stronger, glueing would be lighter but not as strong.
I would probably use rivets (I think that's what I saw) they seem very small and light - more sturdy than glue.
But then there's the chance you could rip an unrepairable hole in the body whereas glue would just detatch?
My opinion: rivet it.
Old 02-06-2011, 04:17 PM   #60
MackanG;
Sorry for the slow reponse. We recieved the EFRA numbers from EFRA on *Jan 5th 2011 - for the #1521 Protoform P56 and the #1524 Protoform P37.
(*4 weeks late due to illness of the key EFRA body homologation guy)
The numbers were engraved into the mold's windshields the same day. Everything produced from those 2 molds since then has the approval number in the lexan.
Dale - Protoform
