Old 10-20-2010, 06:18 AM   #16
Geberit's Avatar
What to buy P37-N Light weight or regular weight? What are the advantages and disadvantages of using one or the other?
Regards
Geberit is offline   Reply With Quote
Old 10-20-2010, 08:36 AM   #17
JLock's Avatar
Regards
It depends on whether you are going to be over the legal minimum weight or not. If your car is a pig and you are trying to do things to shave some weight, you would try going with the light weight body. If your chassis is already light and you need something that may get you above the legal weight minimum, you would then go with the regular weight body. That is the way I have approached the body issue.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 10-20-2010, 09:25 AM   #18
Geberit's Avatar
And how much is the weight difference between regular and light version?
Old 10-20-2010, 11:26 AM   #19
JLock's Avatar
It depends. I have seen the weight difference be as little as 10g or as much as 50-70 grams. It varies between bodies and manufacturers. The thing is to weigh your car without the body first, get the reading, then re-weigh your car with the body.
Texas 5
Old 10-20-2010, 01:04 PM   #20
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
About 15-20g depending on paint.
I find the Protoform light weight version to be very durable (alot stronger compared to the Chevy/Audi etc)
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 10-20-2010, 07:10 PM   #21
Did you guys follow the cut lines for the rear windows or did you cut the entire window out ?
jelayne is offline   Reply With Quote
Old 10-21-2010, 03:01 AM   #22
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
The lite body will save about 15-20 grams as somebody else said.
If you can afford to have a body that won't last quite as long, run the lite body. Not to save weight, as the body is the highest piece on the car. The car handles better with the lite body even if you add weight to make the car weigh the same. If you are willing to run a less durable body, always run a lite weight.
I didn't cut on the lines. I use a hole saw and make 2 holes in the rear windshield. I don't think the cut lines on the rear window allow enough air to escape but that is my opinion. I may try it with a smaller cooling hole as it is now cool enough outside that I can cut down on the air flow going into the body. Less air coming into the body means the area needed to vent it can be smaller.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-21-2010, 09:57 AM   #23
ATOMIC's Avatar
I used the cut line in the rear window this past weekend at the ROAR region 9 championships, I had no cooling issues what so ever. Body worked great.
ATOMIC is offline   Reply With Quote
Old 10-22-2010, 12:00 AM   #24
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Yea, but did u win sucka???
BigDogRacing is offline   Reply With Quote
Old 10-22-2010, 11:01 AM   #25
ATOMIC's Avatar
Yes Sir , Thanks for asking.
Old 12-07-2010, 12:50 AM   #26
Can anybody tell me the differences between this P37 and the P56? Im getting a new body, so which would be better to get?
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 12-07-2010, 02:42 AM   #27
They are both quite good. Get one of each and decided for yourself.
Old 12-07-2010, 04:42 AM   #28
Hahah, I have the P56-N, but I haven't really been able to test it due to not having the right setup for the track I'll be running at - just all over the place, pretty much driving slow to get the feel of the track. It felt nice, but I haven't been able to see its full potential as of yet. I may this coming weekend, but Im divided on whether to go to another track and race electric, or another track and run nitro Only thing stopping me is not having any spare plugs on hand, or any more wheels left! Its a Picco JLR Evo 3, so would an OS 6 or 7 be fine (if you know) Its a fairly long track, 65m straight, so Im leaning towards the 7.
I'll still be getting either of the two bodies, but is there any preference towards one of them?
Old 12-07-2010, 07:28 AM   #29
GREGORY!'s Avatar
you don't need a different body.
you need a new set-up!
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 12-07-2010, 06:16 PM   #30
Actually, I do need a new body, because the holes Ive cut into the windsheild nearly take up the whole thing!
As far as setup goes, I've been told to start with the RRR box setup because it's pretty close to where it should be, but I use a completely different setup for another track, so I couldn't be bothered reverting each week.
Only 1 more race with MY setup, and then it's either back to box setup, or if another racer can find me a setup I'm looking for, then it's going to that
All I really need is wheels and new rear driveline parts (it has mega-slop!!)
I'll probably get the P37, since it's slightly newer than the P56, and I'll more than likely only use it for a week if it doesn't get destroyed!
