Old 08-03-2004, 09:38 AM   #31
NiMo's Avatar
7000 good for rear diff, you will need 50,000 for the front.
Ballrace, UK word, means putting ball bearings in instead of the bushes, which you have done.
Diffs are the same on both cars, where you have one bar across the diff with gears each end, the R has another bar crossing with two more gears. Just makes it able to withstand more power.
That's called toe out.
Front toe out should be about 1 degree, never run an IC car with front toe in.
NiMo is offline   Reply With Quote
Old 08-03-2004, 10:30 AM   #32
Default FW-05S
hey guys yes these cars are fantastic (but you all know that)
i was wondering if any of you have any set-up guides,
the hop-ups i put on my 05-S
are the 2-speed,the R tank,ballraced my steering aswell as the alloy arm,the blue alloy shafts and alloy brake stopper,front unis, the alloy drive washers and alloy muffler stay and put the four bevel gears in my rear diff and this car kicked a RR EVO's ass today at the track,he was not happy
retrochef is offline   Reply With Quote
Old 09-06-2004, 04:48 AM   #33
I just finished building my FW-05s last week and run it for the first time on the weekend. This is my first car and I am hopeless with anything mechanical so building it was a struggle for me. Lucky I have a friend who helped me
Getting the engine started was a real hassle. It just would not fire and all the factory default settings were not what they were meant to be. After about 20mins we got it to fire but we never got it running right. Right now it runs very rich and stalls every now and then. Hopefully we can get it sorted next weekend.
The car did impress though with its handling, braking and turning better than the TC3's on show. Its just gets hammered on the straights, got to sort out that engine and get a two speed.
Here are some pics
nasanu is offline   Reply With Quote
Old 09-07-2004, 06:20 AM   #34
BrainTeased's Avatar
does anyone have setups for the FW-05S with rubber? im hopeless at running rubbers... everything seems so sensitive...
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 09-07-2004, 08:59 AM   #35
NiMo's Avatar
Camber: f -1, r -2
Toe: F +1, r -2
Rear Upper Arm: inner upper hole, outer lower hole
Shocks: f 40wt inner top mount, r 40wt outer top mount
Diff Oil: f 50k wt, r 10k wt
Roll Bar: f flat, r gold (hardest)
(Rear bar must be used to stop power on spin outs)
Springs: front 2 grades softer than rear (ie: f 1.6, r 1.8)
Tyres: same front and rear
Tyre Insert: no air gap, f medium, r soft (I use Echo 4432m 4430s)
Each wheel must have 2x 5mm breather holes for cooling
Ride Height: f 5mm, r 7mm
Use Protoform MG ZS body for best performance.
Old 09-07-2004, 10:13 PM   #36
Originally posted by NiMo
Camber: f -1, r -2
Toe: F +1, r -2
thanks for that Nimo. with the breather holes do you put a hole through the profiles of the tires? (side walls)
and i will have to get sway bars for the FW-05S and will also have to try that body
Old 09-08-2004, 05:17 AM   #37
NiMo's Avatar
Do not drill the tyres!!
Put the holes at 180 degrees in the centre line on the wheels.
Old 09-08-2004, 07:29 AM   #38
ops thanks nimo!
Old 09-28-2004, 04:04 AM   #39
Anyone have any info on the FW-05T?
For less than the S your getting a 2 speed and radio gear on top of the normal S package, or so it seems...
Have they skimped on anything? How can they offer this at that price?
Old 09-28-2004, 04:49 AM   #40
the FW-05T includes a GX15R where as the FW-05S includes the GS15R.
the T would have no hope against a FW-05S with a single speed anyway apart from that i can understand japanese from the kyosho site.
Old 12-19-2004, 02:23 PM   #41
Default Toe adjustment and Engine settings?
Can any give me some advice on adjusting the toe on the front wheels. The FW-05S comes with plastic/resin? ball cups which are screwed all the way in to touching by default.
This seems to give 4 or more degrees toe out, is there a replacement se ot ball cups with turn buckles that can be used for this car? or is it a case of removing them and adjusting them by 1/2 turns?
Also, Can anyone tell me the settings theyt have on the stock GS engine that comes with the 05S? we are currently running with the low speed screw 1/2 turn in from default and the high speed needle at 2 turns out. How far can we take the high speed needle in?
At it's surrent settings we are managing approx 36 Kmph at full speed, using the stock single speed tranny.
nixon is offline   Reply With Quote
Old 12-20-2004, 01:23 AM   #42
with the toe rods you can use mugen titanium or kyosho's FW-05R turnbuckles.
and also replace the ball cups with 4.8mm ones, but you will also have to change those 5.8mm ball screws with 4.8mm ball screws. will try to get some pics of my FW-05R for you tonite.
Old 01-06-2005, 07:06 AM   #43
I have an FW-05RR conversion kit heading my way for my 05S. Kind of pisses me off because I just broke and replaced the front shock tower and suspension arms
Anyway will all of the RR parts fit onto the S? Will I be needing any R parts as well?
Old 01-06-2005, 07:31 AM   #44
you will need a few R parts as you will be ditching the old radio box that is on the top deck of the S
but good thing is you will now have a carbon fibre top deck which looks awesome.
you will also need a flat battery pack.
i hope you still kept all your plastic part extra's that came with the FW-05S kit.
Old 01-06-2005, 10:20 AM   #45
I kept all the bits... But a flat battery pack? From the pics of the R it looks like it uses a normal battery pack just in a different position?...
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
