Which body to use??
#31
I think it is time the EFRA, ROAR etc and the manufacturers must do more with aerodynamics to bring the looks back as we had back in the 70's and 80's like this:
#32
Suspended
#33
#34
Why do you think it is slower?
With a good reverse airplane shaped rear wing you can get as much or even more downforce than those ugly bodies we now have with less aerodynamic resistance. One of the reasons the EFRA wants to go to 160mm is because the looks, there is even talked for a next step to 150mm.
Also slowing down to save fuel, engines and tires is mentioned.....
Funny that on national level the 1/8 in Holland is the most populair class to drive in while the cars are far from real. In other countries the 1/10 is populair because the looks, it is closer to the real thing.
#35
Of course, 30 fronts with 37 rears might solve that
#36
Also, some of the stability we are seeing from these high, jacked up bodies isn't all from downforce. Those huge, slab sides also generate a LOT of side force through the corners. A proper wing on a lower body may make more downforce but will have less side force unless the end plates are enormous.
#38
Suspended
Fuel milage is a non issue, we qualify in 7 minutes. The sportsman class qualify in 5 minutes where the mayority manage 5 minutes. Tires as well, I see a tire change in a main final and maybe 2 if there is a big difference in laptimes. Nothing changed there the last 4 years.
Realistic, does that also mean a diffuser, additional holes, additional wings?
Regarding this old fashion body, they are designed for ols fashion cars. The car / geo of today is based upon our current bodies. So a hughe change (back to low DF bodies) will result in new designs and therefore higher cost for the end-users and a risk for our sport.
#39
Athough we are drifting off, the new 7 minutes rule did change a lot in my eyes. We now do have 3.5 minutes qualifying engines which as promised would not come...
New design bodies with separate rear spoilers will result in higher costs? Just a page ago it was mentioned to have several bodies with different mounting holes to give it a try what is OK to drive with, not to mention the lightweight bodies which last just 1 race, so what is cheap or expensive?
#40
Suspended
