Old 08-26-2010, 03:04 AM   #31
roger999's Avatar
yep i know what screw is for what... My problem was i was turning to much not for 1/8 turn or 1/16. I thought 1/4 or 1 /2 is ok.
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 08-26-2010, 09:13 AM   #32
Geezatec's Avatar
Originally Posted by gfilos View Post
actually, shifting screws are 3x12mm and gap screws are 3x3mm. Shifting screws need a 2mm allen and gap screws need 1.5 allen. No need to paint them also...
I recommend painting the screws of ID purposes. Especially as old as I, we need to, 2x more, I only have one eye!!!
@ roger999 all adjustment screw are screws. 1/8 or 1/4 turns for adjustment. It doesnt mean you can only adjust it that way. Since screws, you can adjust as minutely as nessesary, a hair if needed.
Geezatec is offline   Reply With Quote
Old 08-26-2010, 09:40 AM   #33
gfilos's Avatar
ok, thats a reason for painting them! however i think that is easier and quicker to remove the shoes for adjusting them rather than adjust them with the 2 speed mounted. But thats me.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 08-26-2010, 10:16 AM   #34
roger999's Avatar
yep understand, but what i mean is: i should adjust only 1/8 turn and would be ok i think, i did it too much. will try Saturday again...
Old 08-26-2010, 10:35 AM   #35
Geezatec's Avatar
Never a quick way of doing these adjustment.
1) engine adjustments
2) Centax Clutch engagements
3) Shifting to 2nd gear.
All adjustment of 2sp gear box depends how the car runs, Centax depends on RPM the clutch engages, not only when it engages, but the pessure it put on the clutch bell. 2nd gear depend on the track you drive on.
Like I say. Never a quick way. it does take patience to perfect, and time.
Old 08-26-2010, 10:41 AM   #36
Geezatec's Avatar
Just remember!! The HSN & LSN is like the hot & cold fauset in the kitchen. As small as the nitro engine is, It'll take less to adjust. 1/32nd, 1/64th - a hair!!! Can make a differance.
Good Luck!
Old 08-26-2010, 11:06 AM   #37
gfilos's Avatar
i just said its easier and quicker sometimes to remove the shoes in order to adjust the shifting screws rather that doing it with the shoes attached on the car... from the little holes at bell.....Nothing more or nothing less...
Old 08-26-2010, 04:12 PM   #38
Geezatec's Avatar
To each his own! What ever is easier for the individual.
Old 08-28-2010, 01:51 PM   #39
roger999's Avatar
Default DONE!!!!
Hi, been on the track today... And is done! My car is set perfectly! Gearbox working wery well (done 2 shoes just for case if needed)... Engine is very powerful, not like Orion... (by the way Orion had 0,5mm shims on head)... Zx is great, i didnt know that b4 ))
Thanks to everyone for help!!!!! Thanks lads!
Old 08-28-2010, 02:02 PM   #40
gfilos's Avatar
i told you that you ll be happy with the performance of the zx12 ds2 If you like it,
consider the new mega ds4 or picco evo4 over O.S. They are even better from ds2 (more reliable due to new conrod), and they are cheep too.
Always remember that picco also need a picco pipe for best performance. If you can find a 2607 or
a 2651 picco pipe for your zx12 you ll have best results-the power increase is huge.
Old 08-29-2010, 02:20 AM   #41
roger999's Avatar
i have 2602 now, very old but working fine
that engine is old, so im not sure how long i can race on that, any way current season is going to be end so i need something for next thats why i decided to buy OS.. Rebuild ZX is a bit expensive...
How much is mega ds4 and where i can see it? I didn't find that on the web...
Old 08-29-2010, 02:32 AM   #42
gfilos's Avatar
if you found the zx quick with the 2602, then you havent seen anything yet...As far as where to find mega ds4, check the serpent distributor in your country. Picco evo 4 is the same engine and you can find it into 2 versions:standard and edo modified. I know rcmushroom has both versions in very affortable prices, edo modified is at 239.99$. You cant go wrong with these engines. Very fast and reliable too.
Old 08-29-2010, 04:05 AM   #43
roger999's Avatar
ok, what pipe will you suggest for picco evo4 ? Picco 2651? and witch one will you pick? i mean edo or normal one?
picco evo edo + pipe 2651 will cost me about 250E....
Spec-R Gear diff review P.I.M.P Electric On-Road 890 08-31-2013 05:16 AM
jumping tips????? tweeter79 Electric Off-Road 22 08-01-2009 11:00 PM
Gearing Help/ SPUR GEAR stripping ! rc18r TomElEctric! Micro and Mini Scales 12 04-06-2009 09:25 PM
Jumping back into the ring -- Looking for the right setup Altrodesigns Electric On-Road 13 05-24-2005 05:25 PM
gear ratio 101 - gearing more important than motor? cybertoolzz Nitro On-Road 15 04-01-2003 06:49 PM
