Old 08-18-2010, 02:29 PM   #1
Default Maintenance on one way bearing on first spur gear
Is any maintenance needed normally on the one way bearing on the first spur gear? I know you should keep a thrust bearing greased up every run, but this bearing has no grease and it wasn't noted anywhere that I should grease it. Should I take it off the collar/shaft and clean it up once in a while? Reason I ask is because this part failed (yes all bearings can and will fail eventually) and I was wondering if it was lack of maintenance that caused the failure.
Dredd is offline   Reply With Quote
Old 08-18-2010, 02:43 PM   #2
Get yourself some good quality one-way oil clean the one_way bearing few drops off oil and your done hope that helps
ARC R10/2015 - HOBBYWING - PROAMPS - ORCA
BRCCC
elche_83 is offline   Reply With Quote
Old 08-18-2010, 02:49 PM   #3
Serpent_Gordo's Avatar
Try only one drop, then put it in spin it. Take it out wipe of the shaft, then put it back on and you're good. If you have to much your 2 speed wont engage because it will be slipping. I would do it at the start of the day, then again before the main. But make sure there isn't too much.
Serpent America, Picco, KO Propo, Maxy's Racing Fuel, Enetti, Mi Familia
Christian Lopez
Serpent_Gordo is offline   Reply With Quote
Old 08-18-2010, 02:53 PM   #4
Geezatec's Avatar
one-way clutch work just as much as the thrust bearing. Clutch aways working under acceleration it locks up, Decel its freewheels. Racers lube them b4 finals heats. Go though them after practice, Prelim heats, and final heats. It doesn't take much to lube, just remove the whole gear assemble from shaft, clean and lube with one-way lube or gease.
Geezatec is offline   Reply With Quote
Old 08-18-2010, 02:58 PM   #5
gfilos's Avatar
maybe it was lack of maintenance, maybe the bearing wasnt good, hard to know. However, some maintenance is needed once in a while. I do take it apart before every race weekend, clean it, apply one drop of oneway lube. I havent had any one-way bearing failure the last 3 years.Actually, i am using the same bearing the last 2 years.. Btw, check the 2sp shaft/collar for wear at the point where bearing engages.
I am using serpent one-way lube.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 08-18-2010, 02:59 PM   #6
So it does need a bit of oil...I see. Ok so before every run each day I'll go ahead and add this to my list of needed maintenance prior to taking the car out.
Yeah I replaced the collar as well because it looked worn as well. I'll remember to lube it some. Now the stupid question. Is there a difference between one way lube and something like Mobil 1 synthetic oil, marvel mystery oil, or 3-in-1? I know people substitute some oils like after-run for these products with no issues.
Old 08-18-2010, 03:00 PM   #7
gfilos's Avatar
dont apply too much oil, one drop will do the trick. If you apply more, ow bearing will slip!!
i am not sure if another lube will do the same work, if i were you i would buy a specific ow lube. After all isnt expensive and you ll have it for life.
Old 08-18-2010, 03:21 PM   #8
Roelof's Avatar
Send a message via ICQ to Roelof
When you want to replace the 1st gear adapter it is wise to replace the shaft as well. Starting with both brandnew does give the longest life.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 08-18-2010, 03:31 PM   #9
helivaguy's Avatar
Trader Rating: 42 (100%+)
+1
The only thing that is "still like new" is the box it came in..
Only a half gallon through it my Ass!
helivaguy is offline   Reply With Quote
Old 08-18-2010, 03:37 PM   #10
blis's Avatar
Yes, there is a different in One Way lube and general lube. One way lube allows the cam-like rollers to grab where as a regular lube will make the one-way slip.
The results of using wrong lube on oneway make the gear changing sound like the clutch is slipping. This also happens sometime if the pitman dumps fuel over the gears.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 08-18-2010, 10:57 PM   #11
NiTrO BoOsTeR's Avatar
you can also use a oil from castrol called dextron 3 or any other automatic gearbox fluid as it shares the same properties as 1way lube, it needs to lubricate as well as grip (same as an auto gearbox)
Mitch
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 08-19-2010, 04:23 PM   #12
PDX-Spike's Avatar
Xray makes a one-way bearing lube. Part # 309580
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Old 08-19-2010, 09:31 PM   #13
Amazingly I have had the same 3 kyosho one-ways for years and have never touched them and they are dry as a bone. Other cars seem to need near weekly maintenance or they will slip and I have seen guys with Kyosho's go bad too.. I think there is only one maybe two bearing suppliers that make oneways for our size anyway so they are probably all the same.
You want to use a oneway specific lube from what I remember from back in my electric days, Serpent (Xceed formula now I think) used to be the only thing available but I would trust Xceed and Xray equally, whichever you can get.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 08-20-2010, 02:24 PM   #14
My one way is inside a Kyosho Lightweight First gear housing on a V-One RRR WC (pre evo). It was probably 2 years old when I got the car and went bad about a year after I started running it. I bought the car used, but everything was mint condition (minus some minor scratches on the chassis etc). I guess it's just one point of wear and tear on the cars. I never lubed it, no idea if the previous owner did either. I did notice in the Kyosho manual it doesn't mention anything about lubing the bearing prior to instillation. It comes dry so I had no idea if it needed lube at all. I figured I should ask before I get it all running again just in case. Better safe than sorry.
I'll be picking up a bottle of lube today if the local shop has any.
Tamiya Championship Series Neil Rabara Racing Forum 21237 Yesterday 09:55 PM
