Old 08-18-2010, 01:35 AM   #1
Default having brake problems
Hi people I have a Kyosho Evolva M3 and I'm having problems setting the throttle with the brakes.when thr car is in neutral I can push freely bur then the brakes don't reli brake that well.I know it sounds like I need to tighten brakres but ithen the car will be stiff in neutral,I,e the brakes will come on when I leave the throttle without putting the breaks on.If anyone could help me I would be greatfull
Cheers.
kyoshoevolvam3 is offline   Reply With Quote
Old 08-18-2010, 02:00 AM   #2
gfilos's Avatar
Cheers.
adjust (increase) ATL rate on your transmiter so as to achieve bigger movement of the throttle servo when on brakes. This way you wont have to tighten the brakes so much and at neutral, car will roll freely.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 08-18-2010, 02:28 AM   #3
Is the ATL the throttle adjustment on the transmitter.Would this mean the idle would be needed to be set to the transmitter settings ?
Old 08-18-2010, 02:38 AM   #4
gfilos's Avatar
yes the ATL setting is on the transmiter. Idle wont needed to readjusted. What it does is increasing the backwards movement of your throtle servo. One other
way to do it is increase the EPA (End-Point Adjustment) of throtle servo, on brake direction. Its pretty easy, just read the manual of your trasmitter. Btw, which radio do u have?
Old 08-18-2010, 02:49 AM   #5
At the moment I have a basic futaba 2pl I know its not the best radio I want a Spektrum dx3r.
Old 08-18-2010, 03:06 AM   #6
gfilos's Avatar
i think that 2pl doesnt have a ATL function, so just increase EPA on brake direction step by step until you are satisfied with your brakes.
btw, on a 1/8 car you normally dont need instant braking because brakes apply on the rear wheels only. Experienced 1/8 drivers can tell you more..
Old 08-18-2010, 03:57 AM   #7
kai888's Avatar
Trader Rating: 17 (100%+)
i think what you need to do is adjust the throttle trim so breaks aren't engaged when in neutral and then adjust the linkage for the throttle so it remains at smallest opening when at neutral.
kai888 is offline   Reply With Quote
Solution for the stock class problems Owen RaCing Electric On-Road 503 02-27-2010 08:00 PM
I'm having electrical problems, need some help. lowcel Radio and Electronics 29 01-02-2010 07:00 AM
brake problems kn0bbyba11 Nitro Off-Road 17 05-27-2008 05:06 PM
xray t2 problems?? fishnfst Electric On-Road 6 10-09-2007 10:18 PM
general nitro questions and problems Uneke Nitro On-Road 18 10-05-2001 06:56 AM
