Old 08-17-2010, 10:50 AM   #1
Default clutch bell and wheels don't move when i push car backwards
Hi there people ive just only noticed something with my car when its sitting on the floor and i push car forward the clutch bell and spur gear go freely but when i push back the car dosnt move and its not the breaks but there is a bit of wear on the first spur gear can any one help me out on this.
cheers
kyoshoevolvam3 is offline   Reply With Quote
Old 08-17-2010, 11:04 AM   #2
gfilos's Avatar
cheers
why dont you remove the 2 spurs from the 2sp shaft and try again to see if it rolls backwards. Its about 2 minites work.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 08-17-2010, 11:07 AM   #3
yes the wheels move back when spur gears removed but not when there on for some reason
Old 08-17-2010, 11:08 AM   #4
nitrodude's Avatar
So what if it wont roll back, the car drivers forward, not in reverse.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 08-17-2010, 11:13 AM   #5
gfilos's Avatar
does the clutch bell spin?
Old 08-17-2010, 11:14 AM   #6
gfilos's Avatar
i didnt know of that! lol
Old 08-17-2010, 01:17 PM   #7
kmichael's Avatar
Had that problem before it's the one-way in your two-speed. replace if cleaning & oiling don't work.
kmichael is offline   Reply With Quote
Old 08-17-2010, 02:09 PM   #8
Geezatec's Avatar
With car on the ground, and thumb on the gears, You should be able to roll the car backward. Thumb on gears, you should be able to roll the wheels forward. That will tell you your drive are ok. Also tells you the one-way cluych is good. Clutch may not engaging.
Geezatec is offline   Reply With Quote
Old 08-17-2010, 02:09 PM   #9
gfilos's Avatar
even if the one-way bearing is bad, this wont stop the car from rolling backwards.
Old 08-17-2010, 03:49 PM   #10
Vasilis's Avatar
most likely your 2nd speed clutch is engaged.
Shepherd Velox V8 eleven - RB C10
Shepherd Velox V10 - RB T10RC
Xray XB9 - RB BXR
Vasilis is offline   Reply With Quote
Old 08-18-2010, 02:22 PM   #11
Basically if you grab the gears and roll the car backwards it should feel hard like it doesn't want to go because the one way bearing is locked onto the collar/shaft of the spur gears. If it rolls freely backwards when you grab the gears then the one way bearing is not grabbing and the car will not function properly.
Another easy way to check is to manually push the spur gears and the car should roll. If it does not then there is a problem. My car was like this (Kyosho V-One RRR WC) and needed a couple small parts and about 5min of work to get back up.
Dredd is offline   Reply With Quote
Old 08-21-2010, 01:16 AM   #12
TC_Tuner's Avatar
Trader Rating: 34 (100%+)
+1
Airtronics | Byron's Fuel | Pro-Line | OS | Kyosho | Ballistic Batteries | RIP Al's Hobby Shop
MRX4-X F180 Cobra Zipper Kart Yokomo BD Cup Racer FM1e Recoil M18 Pro Scalpel dNaNo Baja 5T HB D8 Vorza ERevo Savage Flux SCX10 GT2 T4 Slash Ten SCTE Blitz ESE HB Cyclone D4 Mini ERevo Vendetta ST Mini T Micro T
TC_Tuner is offline   Reply With Quote
Perlis Remote Control Club (PRCC) hashini Malaysian R/C Racers 6481 05-06-2013 06:59 AM
Trinity G4 - Team Magic G4 E-Type puma1824 Nitro On-Road 3128 10-04-2005 05:17 AM
