Old 06-11-2004, 09:16 AM   #1
ttso's Avatar
Default Anyone here also using locked rear differential on 200mm GP?
Last weekend my V1RR rear differential suddenly locked for no reason (I have no clue what cause it). I immediately feel different driving characteristic on my V1RR and I like it (small controllable drafting while entering the corner). The only problem I found is my rear tires wear much faster than before.
Anyone here also using locked rear differential on 200mm GP? I know all (or almost) 1/8 GP using no rear differential. How about locked rear differential on 200mm GP? Beside rear tires wear much faster, is there any other con?
Thanks.
ttso is offline   Reply With Quote
Old 06-11-2004, 11:07 AM   #2
mckrooz's Avatar
Send a message via AIM to mckrooz
More fuel consumption. Because of the driving style needed to drive the solid, you need to stay on throttle more than if you had a diff.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 06-11-2004, 11:21 AM   #3
jeffreylin's Avatar
R/C Tech Charter Subscriber
Instead of using a fully locked one, you can use a limited slip diff like the TCD gear set from Kyosho that will provide diff action going into a corner but locks up when power is applied.
jeffreylin is offline   Reply With Quote
Old 06-11-2004, 11:22 PM   #4
compaq888's Avatar
Send a message via AIM to compaq888
hmm
compaq888 is offline   Reply With Quote
Old 06-12-2004, 01:03 AM   #5
mckrooz's Avatar
<cough>Negative Diff<cough>
Kyosho RRR Evo2
Old 06-13-2004, 03:19 AM   #6
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default solid axl
u can't use this on a technical track.. just larger sweeping tracks
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 06-14-2004, 04:55 AM   #7
sorry to ask but what does the Negative Diff do ? is it some thing like the kyosho TCD(LSD) ? and who makes it ? any info abt the characteristics on both types ?
tukibird is offline   Reply With Quote
Old 06-14-2004, 07:04 AM   #8
teammpp's Avatar
The negative diff is made by Kawahara. Just the same as the Kyosho LSD.
It acts like a normal diff at slow rpm during the corner and once it reaches a certain rpm it locks like a solid axle. Uses a shoe type clutch same as the gearbox.
teammpp is offline   Reply With Quote
Old 06-14-2004, 09:38 AM   #9
thanks Palmaris Europe so which is the better diff to get ? some of my friends who use the kyosho lsd said its not very good ..... not sure abt the Kawahara diff know the web page for the Kawahara diff ?
Old 06-14-2004, 09:48 AM   #10
teammpp's Avatar
I would definately say the Kawahara unit is better. I personally never bother with them. Both units add a lot of rotation weight which hurts on tight tracks. They are better suited to faster flowing tracks with a couple of tight turns.
The website is www.kawahara-racing.co.jp
Old 06-14-2004, 09:52 AM   #11
know anyone who run 2 lsd in thier car ?
and thanks for the web page
Old 06-14-2004, 09:56 AM   #12
teammpp's Avatar
Never seen it done before. Might be something to look into. Would need to set properly or it would cause serious handling problems in the corners.
Old 06-14-2004, 10:02 AM   #13
Thanks again will look around to see anyone using 2 lsd to run want to know how it runs
help with locked differential Joe18 Electric Off-Road 3 12-26-2007 07:13 PM
Locking Rear Differential for Yokomo Drift Car uniquexme Electric On-Road 3 04-30-2006 05:10 AM
NTC3 rear differential Speed_Racer R/C Items: Wanted to Buy 2 09-19-2005 01:24 AM
Tightening lossening front or rear differential Intermision Rookie Zone 3 10-13-2003 06:05 AM
Part Number For locked centre pulley for trf414mii. Rear diff question Calvin Ng Electric On-Road 2 05-12-2003 10:41 PM
