Old 08-11-2010, 08:07 AM   #1
Default Balancing car
how do you guys balance your car left/right?
are the hudy pins accurate?
http://www.amainhobbies.com/product_...lancing-Tool-2
or the best way is to get 4x 500g/1kg scales?
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 08-11-2010, 11:17 AM   #2
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Nothing is more accurate than than the scales. But I believe DS has stated that the suspensions, shocks, anti-roll bars will affect somewhat the readings.
I do use the hudy pins and they are a great way to see where you need to add weight.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-11-2010, 12:30 PM   #3
I have 4 scales, but I usually use 2 to balance the car.
The hudy pins are great if you want close and quick, but they have a large sticking point (30-50g per scale if you remeasure what you thought was center)
You need to balance the chassis, and also the suspension. The chassis is balanced without roll bars and equal shocks (length and tension) plus setup wheels.
The suspension is easier to do with something like the old MIP or hudy tweak board to adjust the preload on the sway bars without shocks, and then preload on the shocks.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 08-11-2010, 06:08 PM   #4
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Brian, can you explain how you adjust the swaybar preload and balance without shocks on tweak board please?
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 08-11-2010, 10:56 PM   #5
can you tweak the car manually without the tweak station?
can you adjust tweak using scales? eg, place 2 wheels up on scales and the other end on a board? or do you need a station
im going to buy 4 cheap 1kg scales.
Old 08-11-2010, 11:29 PM   #6
FaanP's Avatar
How do you balance the weight of the car left to right? Do you add weight on the side that weighs less? What kind of weights do you use?
Sorry for all the questions - I'm still learning.
FaanP is offline   Reply With Quote
Old 08-11-2010, 11:45 PM   #7
edit; found it
http://www.racing-cars.com/images/S1...CING_JIG_w.pdf
balance pin on 1 end of the car, and other end a scale on each wheel.
also anyone has instructions on 'how to balance a car using scales' would be good.
Old 08-11-2010, 11:47 PM   #8
js058515's Avatar
I was just using the Hudy balance pins tonight and noticed it was quick but not accurate. Anyone have suggestions on what scales to get? There are a ton on eBay, but a suggestion would help a lot.
js058515 is offline   Reply With Quote
Old 08-12-2010, 12:19 AM   #9
all the 1000g scales on ebay seems the same.. the product seems the same, just a different photo (background) if you look at it..
http://cgi.ebay.com.au/Portable-Elec...t_Equipment_ET
http://cgi.ebay.com.au/0-1-1000g-Min...fic_Equipment2
http://cgi.ebay.com.au/0-1-1000g-1kg...item20b0e97497
Old 08-12-2010, 02:28 PM   #10
js058515's Avatar
I overlooked that, thanks!
What kind of weights do you guys recommend using for balancing?
Old 08-12-2010, 04:29 PM   #11
js058515's Avatar
edit; found it
Thanks for the PDF link. Now I can just buy 2 scales instead of 4.
Old 08-13-2010, 06:12 AM   #12
i brought 4 anyway,
so you can balance the car diagonnally front left/rear right, etc
Old 01-30-2011, 03:08 PM   #13
Red face BALANCING
edit; found it
I studied the instruction.
Is this with or without anti-roll-bars on?
Is this with rubber tyres or better with metal setup wheels?
Kensei is offline   Reply With Quote
Old 01-30-2011, 03:12 PM   #14
DS Motorsport's Avatar
Without anti roll bars and preferably with a set of setup wheels.
Also make sure everything is leveled, especially the two scales.
This is what is posted in the electric thread:
For balancing out the car by using weights I wouldn't suggest putting the car on four scales but one axle on the scales and one on a Hudy pin.
This eliminates the variables like chassis straightness which can cause a false reading.
If you want to do it perfectly you should also replace the shocks with a set of turnbuckles.
First you will dial in the left/right balance on both axles and then the front/rear balance.
When you set it up like this and build your shocks properly you don't have to balance out the car by changing the spring preload. This gives you a very good handling car.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 01-30-2011, 04:49 PM   #15
Default Scale for balancing rc cars
What max weight should one scale have?
I see several kinds.
Up to 200 grams, up to 500 grams, up to 1.000 grams.
I don't know how many grams pressure there is on every wheel of a 1:10 touringcar of about 1.400 grams.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Cebu RC Car Racing Club jpn Manila Racers 14147 05-27-2016 10:01 PM
Team Corally RDX Touring Car Kenshin Electric On-Road 10561 11-21-2015 12:54 AM
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 10:03 AM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 08:57 PM
