Old 08-10-2010, 11:19 AM   #1
Default Measurement of Body Height
Hey guys, I am wondering whats the procedure for measuring a 1/10th Sedan Body Height.
Should the tire diameter affect this height? Should ride height affect this height? Or will the car need to be placed in some sort of blocks (like for Downstop settings).
The hudy's tool says the minimum height is 120mm. Is that the height for all ROAR/IFMAR races?
If I use such tool:
Whats the procedure to do so? With/without shocks? With/without tires? Any info would be greatly appreciated.
Serpenteer is offline   Reply With Quote
Old 08-10-2010, 11:37 AM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
The ROAR rule is from the chassis with car sitting on blocks so ride height and tire size don't affect it.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-10-2010, 12:05 PM   #3
Thanks for the clearup wingracer.
So, to use the hudy body tool, i can just remove the tires/shocks in order for the chassis to hit the setup board?
Old 08-10-2010, 01:44 PM   #4
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
No. I don't remember for certain, but I believe the blocks are 20mm tall.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-10-2010, 03:03 PM   #5
kmichael's Avatar
Yes 20mm
kmichael is offline   Reply With Quote
Old 08-10-2010, 04:41 PM   #6
ROAR Rule book says the minimum height is 130mm with 20mm blocks under the chassis.
And the height in the hudy tool is 120mm, so how do i use it?
Old 08-10-2010, 04:46 PM   #7
DS Motorsport's Avatar
10mm blocks under the chassis.
I always use the Hudy downstop blocks, they are exactly 10mm.
The Hudy bodyheight tool has also been designed to use with the downstop blocks.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 08-10-2010, 05:02 PM   #8
musti72's Avatar
Little off the topic;
Does the Xceed/SRC Cruzer pass the width rule? I have just cut the wheel wells of mine and it seems that side bumpers are bent to outside at rear.
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 08-10-2010, 05:49 PM   #9
P2gee's Avatar
ROAR specifies min. body height of 130mm with car resting on 20mm blocks
IFMAR specifies min. body height of 120mm on 10mm blocks. In the end, same height spec with different measurement spec.
Airtronics M-12
BYRONS Gen2 fuel
Capricorn C802
www.motorists.org
P2gee is offline   Reply With Quote
Sedan Body Shell Characteristics Thread chachi Nitro On-Road 73 07-15-2005 11:39 PM
Body shel scrutineer. MAVICXXX Malaysian R/C Racers 19 06-01-2005 07:09 AM
