Spring color and setup
What is a good spring color for front and rear on a ntc3... I run on a smooth asphault track... A few bumps here and there but overall pretty level.... What is a good way to gauge if you need higher weight springs or lower.. Also do you want higher weight in front or rear... Thanks
usually the response you get for springs and tires is ask other racers what they are using
Thanks man,,, I have a spring kit coming so I will just play around with them... So do you prefer stiffer or softer springs.. What do you have front and rear and what are track conditions that you run
I have no idea Im still learning what is needed for track use
Run reds front and rear 30 or 35 wt oil
Thanks for the info guys... My rebuild on my ntc3. Should be running this weekend...... Can't wait.... D-man. How did the worlds go????
